need advice re my 2004 Jimny which a pothole upset - ABS light on and need pump
07 May 2025 19:01 #260323 by Lambert
That's interesting. And I assume it's not possible to adapt to a different type either eg the control system is specific too?
08 May 2025 08:30 - 08 May 2025 08:53 #260327 by Motacilla
Hello @LoveJimny2004
Good advice from the experts above.
One small point I would add: failure of a wheel speed sensor will also cause the ABS light to come on.  These sensors can fail from a sudden sharp jolt.
Diagnosis is typically by looking at real-time data from the wheel speed sensors, i.e. individual wheel speeds while the car is in motion.  Your mechanic may have already done this test, but if not, it may be worth getting a second opinion.  Wheel sensors are cheap and plentiful, compared to ABS pumps.
Sometimes, simply reading off the error codes from the computer can be misleading.  it may be worthwhile to double-check the diagnosis before splashing out.  (I don't believe that individual wheel speed can be read with a simple OBD reader, so you may need to find a garage with a Suzuki reader or aftermarket equivalent to get deeper into the data than an OBD reader can.)
Again, your mechanic may have already covered this, just mentioning the possibility.
Myself, in ~1 million miles of driving, I've replaced a lot more wheel sensors than ABS pumps -- and given the fine clearances involved, a "pothole upset" is a not-uncommon wheel speed sensor failure mode.
Last edit: 08 May 2025 08:53 by Motacilla.
The following user(s) said Thank You: LoveJimny2004
08 May 2025 10:22 #260328 by mlines
I would agree with Motacilla, are you sure that a sensor was not damaged?
Get someone with a Code Reader to read the fault code.
I note that this company quotes for a specific repair on the Suzuki Pump
www.ecutesting.com/product-catalogue/suz...-combined/amc081a11/
This is if it is showing "C1061 - monitoring current malfunction" in the code reader.
09 May 2025 09:37 #260332 by mlines
The replacement ABS pump is £2,518.  It is currently on back-order which typically means 4-6 weeks lead time on delivery.
The part number is 56100-81A11
I would look at what the fault code is and then speak  to a repairer.
15 May 2025 18:44 #260424 by jackonlyjack
Time to create page: 0.186 seconds
