Gen3 Idle fluctuations
06 Apr 2025 15:23 #260038 by misterpie
Hi All,
I'l really stuck on what to do with this one.
Sons 2000 (W reg) Gen3, 1.3, G13bb engine has the common idle fluctuations problem.
I've checked for air leaks (sprayed brake cleaner around) and checked the PCV valve - all good so time to replace the ICV - I found an affordable one at £40 from JDM. Easy enough to replace even with the 4 screws made of butter, but it's still hunting at idle.
Fuel efficiency is fine, runs great, no miss fires or smokey exhaust.
What else should I look at?
Thanks,
Keith
Time to create page: 0.171 seconds
