Check engine light in suzuki jimny 2015 [p0037]
- Mgadir
16 Mar 2025 21:08 - 16 Mar 2025 21:10 #259828
by Mgadir
Check engine light in suzuki jimny 2015 [p0037] was created by Mgadir
Hello, in my 2015 Jimny. yellow check engine light came on. An OBD test showed that the problem was with the rear oxygen sensor that sits on the catalytic converter. I replaced it with a new sensor. The light went out for a few days and came on again with the same problem. What could be the problem?!
p0037 problem
p0037 problem
Last edit: 16 Mar 2025 21:10 by Mgadir.
- Thank you received: 662
16 Mar 2025 22:08 #259829
Replied by DrRobin on topic Check engine light in suzuki jimny 2015 [p0037]
Did you replace with a genuine sensor or one with the plug already attached? Or was it one you wired in to the plug yourself?
The reason for asking is that the resistance of the O2 sensor is very low and even a slightly bad joint can cause the problems you are seeing.
Apart from a slightly poor sensor, it might be the connector is not making a good connection, or you might have damage to the wiring loom.
The following user(s) said Thank You: Mgadir
- Mgadir
17 Mar 2025 03:31 #259831
by Mgadir
Replied by Mgadir on topic Check engine light in suzuki jimny 2015 [p0037]
No, not original and the plug already attached
Time to create page: 0.150 seconds
