Tyre wear issue.
13 Feb 2025 01:11 #259463
by Fossie
Tyre wear issue. was created by Fossie
A strange one but my front nearside tyre wears on the outer edge, the spare must've been on there at sometime as it a replica wear pattern. The off side wears as it should , the tracking has been checked and is fine .. it's just passed it's MOT so nothing obvious.
I checked the brake cailpers and they slide as they should ...it does pull to the left all the time ...not arm wrenching and all of us that drive it have grown to compensate over the 3 years we've owned it..
The swivel does weep a bit but just a smear ever so often . The kingpins were sorted a couple of years ago and that is probably 8000 miles , so shouldn't be an issue ..
To be fair It's more for my "why didn't I think of that " that I ask ..no one else is bothered
- Thank you received: 1998
13 Feb 2025 06:59 #259467
Replied by Lambert on topic Tyre wear issue.
First thought is it's the roundabout tyre ie the one that takes most wear under normal conditions. Second thought it could potentially be worn or misaligned suspension bushes and or mounting points?
13 Feb 2025 07:25 - 13 Feb 2025 07:27 #259468
Replied by yakuza on topic Tyre wear issue.
My father in law had a Nissan Xtrail that wore out tires a bit fast and only on the (left?) outside. As it was under warranty when bought, he took it to the shop to complain. The seller came up with an amazing theory that the tyres wear out on the outside on one side first from the earths rotation and that on the southern hemisphere it is the other way around. And then said something about it being more obvoius on servo assisted steering.
My Father in-law allmost believed the explanation
First check the tyre pressure, then alignment and of course worn bushes like Lambert says.
As a rough guide you could use a tape measure to check the toe-in. Should be a couple of degrees so a few mm narrower between the front of the front wheels than the back of the front wheels. But not like more than 5mm, then I would take it to alignement
I got a strange one on my Swift where the softer winter tyres wear evenly and the summer tyres wear out faster and unevenly. It is the same offset wheels and sizes. I know it is not so well aligned, I bought it with a dented front sub frame traverse where the lower arm sits. Straightened with a sledgehammer and aligned with eye-sight and a tape measure.
(Not at all recommended!)
But it drives fine and straight-ish.
Last edit: 13 Feb 2025 07:27 by yakuza.
13 Feb 2025 09:40 #259470
by facade
Replied by facade on topic Tyre wear issue.
I'd suspect a bent axle tube if the kingpins and balljoints are fine.
Get the camber angles checked.
The tyres should wear flat across- one of the advantages of a beam axle over poorly implemented "indeependant suspenshun".
13 Feb 2025 12:02 #259472
by Motacilla
Replied by Motacilla on topic Tyre wear issue.
Steering pull and uneven tyre wear point to something bent or worn. Incorrect tyre pressures won't help either, though one assumes that was the first thing you checked.
The MOT is to check for problems big enough to affect safety; that is not what you have here. You want to get it examined in detail by a 4x4 suspension expert to find the problem.
Or ignore it, since there is not much point in trying to fix every little thing on an old Jimny.
13 Feb 2025 14:06 #259473
by fordem
Replied by fordem on topic Tyre wear issue.
I find this an interesting discussion - here's why...
Back in January when I took my JC74 in for it's first service, there was a young lady with a JB74, that, based on the registration, couldn't have been on the road for more than eighteen months or so - she'd brought it in because the near side front tyre was almost completely bald & the other three were fine.
The dealer techs took the car into the shop and they brought both vehicles out at the same time so I was able to "eavesdrop" - their diagnosis was the steering stabilizer which they did not have in stock, but would order & replace under warranty.
My diagnosis matches facades' - it's most likely a bent axle tube.
Time to create page: 0.384 seconds
