Gen3/JB43 Auto can't select park gear
29 Jan 2025 08:17 #259265
by JunkDog
Gen3/JB43 Auto can't select park gear was created by JunkDog
Nz model 2004 Jimny Gen3/JB43 M13a non-vvt with Automatic transmission.
Is used as a farm vehicle, and handbrake is non-functional, so can't use that.
Problem I have is I cannot shift the transmission selector lever to park.
I can select all other gears, and they all appear to be working correctly.
Anyone got any ideas on what I should be checking and where?
I was thinking it could be the shift lock solenoid? But I don't know where to find it.
Or possibly a fuse?
I haven't had time to look or check anything yet, but will try tomorrow.
Or possibly a fuse?
29 Jan 2025 14:53 #259268
by fordem
Replied by fordem on topic Gen3/JB43 Auto can't select park gear
The shift lock solenoid is at the base of the shift lever, you will need to investigate why it's not being energized - it's unlikely to have it's own fuse.
On an SN413 it's powered by the turn/back fuse, I don't know if that holds true for the JB43
29 Jan 2025 15:02 #259269
by Busta
Replied by Busta on topic Gen3/JB43 Auto can't select park gear
Do the brake lights work? The brake light switch also forms part of the gearbox control circuits.
29 Jan 2025 18:37 #259270
by Motacilla
Replied by Motacilla on topic Gen3/JB43 Auto can't select park gear
If the problem is that you can't shift INTO park, then I would see it being the shift mechanism and not the brake interlock solenoid. A mechanical problem (worn or blocked or bent part) and not an electrical one.
Can't shift OUT of park, that is probably the lock solenoid. But it does not sound like that is the problem here.
The following user(s) said Thank You: JunkDog
31 Jan 2025 10:44 #259286
by JunkDog
Replied by JunkDog on topic Gen3/JB43 Auto can't select park gear
So I found time to have a look today.
All the linkage underneath was fairly clean with no obstructions, bends or damage.
I did find a blown fuse in the engine bay fuse box, though I don't think it was related.
It started working when I pulled the shift lever apart, so I'm assuming something was binding up or not working right in there.
Thanks for the advice, suggestions and help.
Time to create page: 0.182 seconds
