Just purchased 2023 jimny tyre advice
22 Nov 2024 16:45 - 22 Nov 2024 16:49 #258455
by wak1000
Just purchased 2023 jimny tyre advice was created by wak1000
Sorry about this as a new member may be in wrong place
I have just purchased a stock 2023 uk jimny with stock dunlop tyres
I am finding this a nightmare to find tyres I want to replace so here goes
Stock ride height no messing around .
Tyres on now are 195 60 r15 s96
I want sum tyres that mainly road use and only gravely mudy lanes if we get caught out
my budgets around 500 pound for 4 plus I can get them fitted
As said no messing lifting etc so dont want tyres to catch
please can someone help on a tyre choice that looks good a slightly bit bigger and wider and will do for wat i explained above
I am in wakefield w yorks
I am at a loss of all the tyres on internet that I no most will not fit my jimny and i am green as the hills on this subject
thankyou john
thankyou john
Last edit: 22 Nov 2024 16:49 by wak1000. Reason: Spelling
22 Nov 2024 16:54 #258456
by jlines
1986 SJ413JX (Lil Red)
2018 JB43 SZ4
2019 JB74 SZ5 (Gerald)
2023 JB74 LCV
Replied by jlines on topic Just purchased 2023 jimny tyre advice
You can go up to 215/75/R15 safely without doing anything to the car. I would look for an all terrain tire for the usage you are intending. BFGs & Geolanders seem to be popular choices but I don't know what fits within your budget.
2018 JB43 SZ4
2023 JB74 LCV
The following user(s) said Thank You: wak1000
22 Nov 2024 16:55 - 22 Nov 2024 19:13 #258457
Replied by mlines on topic Just purchased 2023 jimny tyre advice
Should be a few options in 215/75/R15 around. Try black circles. Not that their website is not good at showing all the options for the request size, you often have to resort to searching based on brand
Last edit: 22 Nov 2024 19:13 by mlines.
- Thank you received: 667
22 Nov 2024 17:27 - 22 Nov 2024 17:27 #258458
Replied by DrRobin on topic Just purchased 2023 jimny tyre advice
Hi,
Congrats on your new purchase, I am sure you are going to love it.
I think your stock tyres will be 195/80R15 (rather than 195/60 as stated).
There are a reasonable number of AT tyres in 195/80/R15 and a lot more in 215/75R15 to choose from without getting too expensive.
If you change to 215/75R15 the diameter is only 1.5% different, however, it is much wider so has more grip and to be honest looks better in the wheel arches.
As Martin mentions look on Blackcircles or better still just put in 195/80R15 AT tyre or 215/75R15 AT tyre and see what comes back.
A quick look shows the following:
Cooper Discoverer AT3 in 195/80R15 @ £99 Blackcircles
Hankook Dynapro ATm 195/80R15 @ £92 Blackcircles
Yokohama Geolandar 205/70R15 @ £91 Blackcircles
Maxxis Worm-Drive 215/75/R15 @ £111 Demon Tweaks
BF Goodrich KO2 215/75R15 @ £165 Blackcircles
I started with Geolandar's, I would describe them as 80% road, 20% off-road, but have a great tread pattern for winter roads, white stone roads and the odd muddy puddle.
I then fitted Hancook Dynapro, they have more of an off-road tread but still mostly road based and ran these side by side with Maxxis Worm-drives up until I swapped from a Gen 3 to Gen 4 and then went with Maxxis Worm-Drives all of the time.
If you are worried about tyre sizes 195/80R15, 205/70R15 and 215/75R15 will all fit without modification and you can compare sizes using tiresize.com/tyre-size-calculator/
If looks are important, I think the look of 215/75R15 fills the wheel arches out better and looks more the part, even if it is just used on the road.
Robin
Robin
Last edit: 22 Nov 2024 17:27 by DrRobin.
22 Nov 2024 17:37 #258459
If you go on Blackcircles you can search by tyre size, then just enter 195/80R15 (or 215/75R15), your postocde and select fully fitted, it orders the results by price.
In 215/75R15 it offers
Geolandar at £132 ea
Toyo Open Country at @£136 ea
(Save 15% on two or more Geolandar/Toyo)
Robin
General Grabber AT3 @ £155 ea
Robin
- Rogerzilla
- Premium Member
- Thank you received: 15
22 Nov 2024 19:03 #258462
by Rogerzilla
Replied by Rogerzilla on topic Just purchased 2023 jimny tyre advice
I had Bridgestone Dueler AT002 in 195/80R15 and they were very good. Look much better than Geolandars, too.
Time to create page: 0.408 seconds
