Gen3 (2010) Jimny Overheating Saga
11 Sep 2024 06:47 #257504 by durfsurn
Confirmed I'll need to replace the Head Gasket. I'm gonna give it a crack with a mate who's handy with a wrench.
Are there any guides online worth following? I have a PDF set of manuals I'll look through as well.
Also any sources for a head gasket kit? I'm located in AUS if that changes things, even part numbers would be helpful. I have an M18A from a Liana which may complicate things but it is the same engine just slightly bigger so hopefully straight forward.
I also have to do a front-driver-side wheel bearing, there is a guide on the wiki, but advice sourcing a good kit would be awesome.
Thank you all for your help.
2010 Silver Jimny M18A swapped
Manual
ARB Bullbar
Jimny Snorkle
2" lift
The following user(s) said Thank You: Darthblaker7474
16 Sep 2024 20:59 #257544 by Darthblaker7474
It may be worth getting the head skimmed and pressure tested before putting it back together.
Time to create page: 0.182 seconds
