Leaking swivel joints
24 Jun 2024 19:12 #256432
by Forde
Leaking swivel joints was created by Forde
Hopefully someone can point me in the right direction here. The swivel joints on my gen3 are leaking diff oil. After spending a bit of time reading through the forum it sounds like the pitted swivel is pretty par for the course and the issue will likely be the kingpin bearings. I see they are out of stock in the shop here so I was hoping someone could point me in the direction of where to buy. Looks like the seals should be replaced too. Anything else I should think about doing at the same time? Thanks in advance
24 Jun 2024 20:29 - 24 Jun 2024 20:32 #256433
by Busta
Replied by Busta on topic Leaking swivel joints
The bearings are 30302 taper roller bearings, available online or at your local bearing shop. Any reputable brand will do.
For the driveshaft seal it's best to get genuine ones. I get them from ebay. Here's a link. In a pinch you can get a generic rotary shaft seal from a bearing shop with the same inside and outside diameters but they don't last as long as the genuine Suzuki seals.
Those are the only parts I ever replace. As you've discovered, the pitted swivel is a distraction really. The swivel seal and surface will never be good enough to keep oil inside, and it doesn't need to be as there shouldn't be oil inside the swivel. So that's nothing to lose sleep about.
The only other thing you really need is some waterproof grease. Smear a good dollop over the top of the lower kingpin bearing, inside the swivel. This is about all you can do to delay the inevitable corrosion!
Last edit: 24 Jun 2024 20:32 by Busta.
The following user(s) said Thank You: Forde
24 Jun 2024 21:03 #256435
Replied by mlines on topic Re:Leaking swivel joints
All in the BigJimny store, link at top of the page. Support the site and forum
Sent from my ThinkPhone by motorola using Tapatalk
25 Jun 2024 06:14 #256438
by Forde
Replied by Forde on topic Re:Leaking swivel joints
That was my first port of call Martin, but they’re out of stock
25 Jun 2024 06:21 #256439
by Forde
Replied by Forde on topic Leaking swivel joints
Thanks Busta. I’m definitely not a mechanic - bicycles yes but not cars. I replaced the rear exhaust section on mine and I know which end to hold on a screwdriver but feel this is probably beyond me - maybe I’m wrong though.
My local garage had a look and said I need a new axle, due to the corrosion and pitting on the swivel but you helpful people here made me realise that’s not the case. I’ve never had an issue with my local garage - would you say the “new axle” comment is just due to them not knowing Jimnys very well?
- Roger Fairclough
- Thank you received: 225
25 Jun 2024 07:36 #256441
by Roger Fairclough
Replied by Roger Fairclough on topic Leaking swivel joints
Jimnys have been around long enough for any decent mechanic to know how the various systems work so your local garage is just pulling a flanker.
Roger
Roger
