Radio issues , locking issues, and then not starting. Driving me mad
- Thank you received: 77
25 Apr 2024 18:43 #255777
by robs5230
standard jimny - for now
Its one thing after another with this Jimny
When its working well, its a pleasure to drive.
Since getting it, it has had issues with the radio apparently losing code and requesting the code, which I have.
Now its recently started playing up when driving, the display showing some kind of hyroglyphics. When its like this, it doesn't respond to any of the buttons, not even on and off.
Then the display has also been going blank, yet still playing cds.
The car has also started to lock it self rather quickly while getting things out of the boot. Only say 15-20 seconds after being unlocked
Just been out after work, and I have a non start
Battery is good, but theres an orange car symbol with a padlock through it, steady orange. Not flashing.
Will not turn over at all.
Got a push to try a bump start and it started instantly. When running the padlock light is off.
I'd imagine all the above are connected related, but short of pulling all the fuses out for the radio, door locking etc, I'm at a complete loss.
Any ideas? Pretty desperate
Thanks Rob
Thanks Rob
- Thank you received: 667
25 Apr 2024 19:32 - 25 Apr 2024 19:32 #255778
Replied by DrRobin on topic Radio issues , locking issues, and then not starting. Driving me mad
The padlock symbol is the immobiliser, if that was on I am surprised it ran, I thought the immobiliser cut the fuel and spark.
Are you sure the battery is good? All of these problems sound a bit like a weak electrical system. If it’s not the battery, do you have a bad connection on a power cable?
One other thought, has it got excessively wet inside or you haven’t had a mouse in, they chew the insulation on the wires and you get some very strange things.
Robin
Robin
Last edit: 25 Apr 2024 19:32 by DrRobin.
25 Apr 2024 23:18 #255781
by robs5230
Replied by robs5230 on topic Radio issues , locking issues, and then not starting. Driving me mad
Hi.
Thanks for the input.
Battery tests at 12.6v and shows a green light.
It definitely bump started and drove home, despite the light.
Mice, I have no idea, but if I have mice, they're well travelled. I do about 150-200 miles a week.
There is a faint clicking when I trigger the key, but not like the starter is struggling .
I'll look at the starter connections tomorrow
Cheers
Cheers
26 Apr 2024 07:41 #255782
by robs5230
In a fit of common sense, I've had a look at the warning light section of the owners manual
It states the immobiliser light comes on when the key is activated to the ignition position, before the final turn to engage the starter
Solid light (which I have), is just showing its working
Flashing immobiliser light, indicates problem with immobiliser
Could I simply just have a starter motor or relay issue?
I can hear a very light clicking when I attempt to start
Thanks
Thanks
26 Apr 2024 08:16 #255783
Re immobiliser light, well spotted. Of course we don’t often notice that as normally the key is turned fairly quickly to start the engine.
It could be something to do with the starter motor or solenoid, it it has one.
Robin
Robin
26 Apr 2024 08:49 #255784
by robs5230
You're going to love this.
Disconnected the battery a couple of hours ago.
Then decided as the factory radio was toast, I;d just unplug it to stop the electrical gremlins.
Had it out, removed the plug from the rear and put it all back, just to look right.
Re connected the battery, and it started first spin.
Bit fuelly smelling for about 20 seconds, presumably as all the attempts to start, have caused the fuel pump to over prime a little, then everything normal.
Took if for a short run, stopped on a couple of hill is case it needed a bump, and it started perfectly both times.
For now, I'll leave it and see how it it. I'd assume I'm being a bit optimistic thinking the radio could be causing starting issues, but at least its one factor eliminated now.
Any more issues, I'll fit another starter
Cheers
Cheers
Time to create page: 0.214 seconds
