My rear door always rattles with the slightest vibration
17 Apr 2024 12:48 #255617
by Vandoni
My rear door always rattles with the slightest vibration was created by Vandoni
My rear door (non-convertible Jimny) rattles a lot, and squeaks in a metallic way, like if two pieces of metal were sliding on each other.
Any way to make that stop? The seals are pretty decent, and the other doors rattle as well, but those seals are old and stiff so I'll change them and see.
- Thank you received: 1999
17 Apr 2024 16:13 #255620
Replied by Lambert on topic My rear door always rattles with the slightest vibration
It could potentially need new hinges. Is there any vertical movement in the door when it's open?
- Thank you received: 667
17 Apr 2024 16:24 #255622
Replied by DrRobin on topic My rear door always rattles with the slightest vibration
There is an adjustable door stop (rubber) on the doors, or you might have to adjust the catch position on the rear door, I have forgotten which. My Gen 3 rear door rattled until I adjusted the door stop.
The bonnet also rattled until I adjusted the rubber stops on that, I think they twist to adjust.
There could be something loose inside the door, the inner cover comes off fairly easily (press clips), so you could check, perhaps the rear screen wiper has come loose?
You might also want to check the spare wheel and spare wheel carrier in case that has come loose.
Robin
Robin
17 Apr 2024 17:39 #255627
by Scimike
Replied by Scimike on topic My rear door always rattles with the slightest vibration
My rear door rattle turned out to be the rear silencer resting on the towbar metal work. It's surprising how sound travels, spent weeks investigating the rear door rattle that never was. So worth a check IF you have a tow bar.
18 Apr 2024 07:19 #255636
by Vandoni
Replied by Vandoni on topic My rear door always rattles with the slightest vibration
I do have a tow bar but my muffler is custom so it doesn't hit, also I adjusted the front door stops and they're good now, but I still don't understand how to adjust the rear door catch position
18 Apr 2024 07:38 #255637
I don’t have a Gen3 now so can’t look, but see this thread
www.suzuki-forums.com/threads/adjust-rattling-back-door.275290/
The post by Fordem (also on here) is the most relevant, he shows adjusting the circular rubber on the door.
Robin
Robin
The following user(s) said Thank You: Vandoni
Time to create page: 0.214 seconds
