Headlight Leveling Motor / switch Wiring
- DavidEdie01
05 Apr 2024 20:28 #255467
by DavidEdie01
Headlight Leveling Motor / switch Wiring was created by DavidEdie01
05 Apr 2024 23:44 #255471
by fordem
Replied by fordem on topic Headlight Leveling Motor / switch Wiring
06 Apr 2024 06:32 #255472
by facade
Replied by facade on topic Headlight Leveling Motor / switch Wiring
The leveller is a servo, and moves until the voltage on the control pin is equal to the voltage it gets from a potentiometer connected to the output gear.
The switch just selects a voltage tap from that chain of internal resistors to feed to the control pin.
You could control it with a continuously variable potentiometer if you wanted.
After many years the potentiometer inside the servo either gets dirty or wears a hole in the track and the servo starts to buzz as it is continually moving very slightly trying to match the voltages.
- DavidEdie01
08 Apr 2024 00:54 - 08 Apr 2024 00:55 #255492
by DavidEdie01
Replied by DavidEdie01 on topic Headlight Leveling Motor / switch Wiring
So far I know some stuff
in my photo,
Leveling motors
1 - connects to the leveling switch
2 - 12V +
3 - GND
leveling switch
judging by the diagram above
two pins of the switch are intended to go to either leveling motor exactly which of the 5 are, can't tell.
the switch has to get some input from the parking lights or something for the switch to show the orange light. so that's another pin
that leaves me with 2 more pins I suspect one of them gotta be a GND too but I'm not sure any help?
Leveling switch
4-
5-
6-
7-
8-
in my photo,
Leveling motors
2 - 12V +
3 - GND
leveling switch
Leveling switch
4-
5-
6-
7-
8-
Last edit: 08 Apr 2024 00:55 by DavidEdie01.
08 Apr 2024 13:03 #255499
by fordem
Can you read a wiring diagram? Do you have a multi-tester and know how to use it?
Assuming the switch matches the one in the diagram, determining which pins are which is a matter of simple resistive tests.
turn the knob to p3 - look for two pins with a dead short between them, those will be pins #4 & #5.
turn the knob to p0 - look for a pin with a dead short to either #4 or #5 that will be pin #3.
look for a pin with some amount of resistance between it & #3, that will be pin #6, confirm by measuring the resistance between #6 & either #4 or #5, the resistance should change as the knob is rotated.
- DavidEdie01
09 Apr 2024 03:11 #255504
by DavidEdie01
thanks for the reply, yeah right now I don't have the switch with me, waiting for it to arrive. I'm trying to get some knowledge in advance
I will try what you suggested
Time to create page: 0.174 seconds
