M13 VVT Oil leak rear of engine
05 Apr 2024 10:26 #255452
by will3942
M13 VVT Oil leak rear of engine was created by will3942
Hi,
I'm having some troubles with my Jimny (58 plate M13 VVT). It's at the mechanic and they're saying it's got an oil leak coming from the rear of the engine.
They say "it's leaking from what looks like a sensor and what looks like a pump". They can't figure out what parts these are and so what needs to be done.
Is anyone able to help me with this please?
Thanks,
Will
Thanks,
Will
05 Apr 2024 11:09 #255453
by will3942
Replied by will3942 on topic M13 VVT Oil leak rear of engine
Bit of back and forth and it turns out this is the cam sensor and the EGR valve seems to be leaking too.
05 Apr 2024 11:14 #255454
by will3942
Does anyone know the correct bolts for the EGR valve? These are really corroded and could do with replacing.
