Engine oil spec
18 Mar 2024 22:51 #255158 by yakuza
Replied by yakuza on topic Engine oil spec
Just tells at what temp the test have been done, not at what temp the oil is suitable for, or a max / min.
Gets -15 here but ordinary oil is ok.
The m16 is speced for 0w-20 but i have in my limited wisdom assumed it was the same engine as the m13 so been using the 10w 30 oil. Even in winter. Or was it 5w40..?
19 Mar 2024 00:15 #255163 by DrRobin
Replied by DrRobin on topic Engine oil spec
The figure before the W is the SAE viscosity at 0 deg C.  It certainly gets that cold where I am.
Not true, the figure before the W is considered to be a winter grade and the SAE measure this at a temperature between -15 and -40C depending on the grade, see  en.wikipedia.org/wiki/SAE_J300 .
The chart shown in this link ( penriteoil.com.au/knowledge-centre/Visco...an-sae-viscosity/180 ) is probably as good as you can find and shows 5w30 as suitable between -30 to 36C and 10w30 as suitable for -25 to 36C, both equally as good for any temperatures we see in winter in the U.K.
However, recent high summer temperatures would suggest 5w40 as more suitable going from -30 to 40C.
Robin
19 Mar 2024 08:05 #255167 by
Replied by on topic Engine oil spec
I thought 0 deg C was in the standard textbook for vehicle mechanics (Hillier) but, checking, that actually just says the W viscosity is at a "sub-zero" temperature, so the author probably couldn't be bothered to look it up!
One advantage of 0W oil is that it should indicate a proper Group IV (PAO) base oil, as it's hard to make a hydrocracked "synthetic" mineral oil meet  that winter rating.  Synthetic *should* mean the base oil has been created by combining smaller molecules to give the exact desired properties, but a legal case in the USA many years ago means any old mineral oil can be labelled "synthetic" after what is often superficial processing.  You can't make a proper synthetic oil and sell it for £20 for 5 litres, as is the case for some of the off-brand stuff in the discount stores.
Not that a gen3 Jimny needs anything better than a good quality 5W30.
19 Mar 2024 11:22 #255170 by DrRobin
A number of Internet sources, including oil manufacturer's suggest the test is done at 0F (-17.8C), the US ones I can understand saying this, but the high temperature is done at 100C which is 212F, so a nice mix of units if that is actually true.
Anyway 5w/30, 10w/30 or 5w/40 won't make any difference in the UK.  The Jimny is not a high stress engine, so almost anything will do.  I can remember my old motorcycle days, the Hondas I had used a mono grade oil, but my '77 Triumph is like the Jimny, you can put anything in it.
My other car uses a fully synthetic oil and if you read the manual it only specifies one make, which of course is twice as much as anything else.  As I don't do many miles my local garage usually only changes the oil every second year, there is no point changing every year it comes out as clean as it went in.
Robin
19 Mar 2024 11:30 #255171 by
I would guess the incredibly thin 0W16 oil in the gen4 is just there to scrape a few tenths more mpg in the WLTP test.  Certainly, if you read the owner's manual, you can use other grades depending on the climate.  I doubt I'll use 0W16 when I come to change it myself.
19 Mar 2024 19:37 #255175 by robs5230
Replied by robs5230 on topic Engine oil spec
Thanks for the input chaps
standard jimny - for now
Time to create page: 0.095 seconds
