Left side electronic window relay location?
28 Feb 2024 09:58 #254673
by SFx124119
Left side electronic window relay location? was created by SFx124119
Hi, I have a Suzuki Jimny 2003 Right hand drive Manuel.
The left side window has recently stopped moving after installing new speakers, I cant seem to find where the relay for the electric windows is located. Has anyone got a wiring diagram or know the location of the relays? Thanks.
- Thank you received: 676
28 Feb 2024 10:15 #254675
Replied by DrRobin on topic Left side electronic window relay location?
I don't think there are any relays. I did find the following diagram
www.bigjimny.com/media/kunena/attachments/1257/snap-4.jpg
As well as this thread from a few years ago
www.bigjimny.com/index.php/forum/7-jimny...electric-window-fuse
The windows seem to use a common fuse, so if only one window is not working, it must be the switch, wiring or motor.
Did you take the door card off, or was it only new speakers in the foot well? Perhaps you caught a cable or dislodged a connector?
Robin
Robin
- Thank you received: 2005
28 Feb 2024 11:23 #254677
Replied by Lambert on topic Left side electronic window relay location?
If the window suddenly stops working ensure that you have not inadvertently pressed the child lock button on the drivers side window switch panel.
The following user(s) said Thank You: Atheling
28 Feb 2024 16:56 #254682
by Phaeton
Replied by Phaeton on topic Left side electronic window relay location?
If it's not the switch on the drivers door there is a 2 pin connector in the passenger door you may have caught that whilst doing the speakers, you can test by either a multimeter or a bulb across the contacts. If it's not that it'll be the motor, not a bad job to change as the glass unbolts off the arms, getting it back in is easier than getting it out as you an then use the motor to get it in the right position to line the holes up.
