immobiliser or ECU for not starting
- greenmachine
Topic Author
- Senior Member
- Thank you received: 5
24 Feb 2024 17:58 #254552
by greenmachine
immobiliser or ECU for not starting was created by greenmachine
Now then all, i recharged the battery and turned her over, heres some history 1st, In her past life i swapped the 1.3 M13A engine VVT (55 reg)
for a 1.6 suzuki swift engine, she ran but was lumpy and missing a bit. now after tracking her down and buying he back she will turn over but wont start and squirts fuel out an injector or the rail. she has the engine light on and another light of a car with a padlock through it, pic attached. i,m thinking thats the immoblisler warning light. so to get her going i need to ask a few questions to narrow it down.
1/ do i need to swap the immobiliser out or the ECU or both?
2/ i have a donor jimny 2001 but its not the VVT engine so am i right in thinking that the ECU and IMOB from that wont work? and its scrap/parts
3/ shall i buy more 1.6 or 1.3 injectors and install those?
I,m completley stuck and i,m starting to think this might be impossible or can someone shed light on where i should begin ?
cheers L.
cheers L.
- Thank you received: 673
24 Feb 2024 18:36 #254555
Replied by jackonlyjack on topic immobiliser or ECU for not starting
Here's the part numbers for injector seals
Take no notice that they're motorbike parts
Ebay will be the cheapest
- greenmachine
Topic Author
- Senior Member
24 Feb 2024 18:41 #254556
by greenmachine
Replied by greenmachine on topic immobiliser or ECU for not starting
mega thanks jack, i,ll look into that, cheers.
24 Feb 2024 18:44 - 24 Feb 2024 18:51 #254557
It will make little difference with 13 or 16 injectors both will be fine
I would say get a good second hand ecu with keys ect
seen them sell for around 80 quid
You will need vvt ecu
Have you had obd reader plugged in to see if it tells you anything
Last edit: 24 Feb 2024 18:51 by jackonlyjack.
25 Feb 2024 06:55 #254564
Replied by yakuza on topic immobiliser or ECU for not starting
If the immo light blink fast there is a problem, if it just lights up steady it is a self test.
Are you sure there is an ecu problem?
Could just as well be the position of the cam sensor ring, coil pack, is there a fuel rail pressure sensor?
- Thank you received: 534
25 Feb 2024 10:06 #254567
Replied by DrRobin on topic immobiliser or ECU for not starting
According to the wiki the immobiliser disables the injectors and the spark.
www.bigjimny.com/mediawiki/index.php/Key...%20unit.&text=4.,ECU .
If you have fuel coming out of the injectors and a spark then it possibly isn’t the immobiliser or the ecu.
Robin
Robin
Time to create page: 0.169 seconds
