Compatibility of Catalytic Converters
22 Feb 2024 19:13 #254523 by tomlil01
Hi, Robin,
My car is apparently SN413V-5.
Am I reading the parts list correctly that this 2016 cat should fit?
cuztoms.co.uk/products/suzuki-jimny-cata...c-converter-2016-29k
Thanks
Lee
26 Feb 2024 17:42 - 26 Feb 2024 17:46 #254610 by tomlil01
Hi, Yakuza
I replaced my second cat with a cheap one and I seem to have no blockage now. Back pressure test on the whole exhaust system is good. Performance seems back to normal.
When I took the second cat off a lot of metallic "sand" fell out, I think from the upstream end. Do you think that since I only replaced the second cat ~1 year ago that this points to the first cat causing the problem? My mechanic looked at the first cat with a special camera and said it looked intact. Also, I did a back pressure test on just the first cat and there was no blockage. However, I am not sure whether the honeycomb might look ok, but be still causing issues by dropping this "sand" into the second cat?
Thanks
Lee
Last edit: 26 Feb 2024 17:46 by tomlil01.
26 Feb 2024 18:16 #254612 by DrRobin
Hi,
It looks like your first CAT has disintegrated and blocked the second CAT. The first CAT doesn't get blocked when it disintegrates as all of the material gets pushed in to the second CAT.
Chances are your second CAT was OK (if it was only a year old), if you could have cleaned out all of the 'sand' like material.
Either way it is now fixed.
Robin
The following user(s) said Thank You: tomlil01
26 Feb 2024 20:50 #254621 by tomlil01
Thanks, Robin. I guess I will replace the first cat as well, so as not to risk damaging the second cat again.
26 Feb 2024 23:16 - 26 Feb 2024 23:19 #254624 by yakuza
Glad you found your soulution.
My two broken cats, one jimny and one Swift, where both so broken it was easy to see.
The jimny one rattled and was 30-40 % disintegrated but visible defects only from the engine side.
The Swift had a big hole thru it kind of melted.
I tried to flush the jimny no2 cat first with air pressure and then water. Put it back without the no1 cat but the car was still lacking in power.
I think the powder burn stuck on to the next cat.
Not sure you need both the cats though, the Swift only got one from New and my jimny pass the mot with only one cat.
Last edit: 26 Feb 2024 23:19 by yakuza.
27 Feb 2024 18:36 #254647 by jackonlyjack
It is possible to smash out the first cat
and it will pass the mot with a good second cat
