‘08 Jimny Rough Idle
- KimiKeemstar
16 Feb 2024 10:17 #254369
by KimiKeemstar
Replied by KimiKeemstar on topic ‘08 Jimny Rough Idle
Hey Roger, just had a quick look at the o2 sensor fuel trims on idle after running it for a while here’s the short term fuel trims and long term fuel trims for reference.
- KimiKeemstar
16 Feb 2024 10:29 - 16 Feb 2024 14:12 #254370
by KimiKeemstar
Hey Robin,
Just did a drive around and did some slightly harder acceleration as well as some higher speeds, around 70kph to see if they induced some symptoms and codes.
The idle seemed to be pretty stable when I drove gently and under 70kph, but after I drove it harder and hung around 70kph, the idle became rough, and the EML started blinking a bit.
I scanned the codes when I got home and I did end up getting more codes.
Here they are:
P0401 Raw code: 0401ECU: 11Status: Confirmed Exhaust gas recirculation (EGR) system - insufficient flow detected
P0113 Raw code: 0113ECU: 11Status: Confirmed Intake air temperature (IAT) sensor - high input
P0102 Raw code: 0102ECU: 11Status: Confirmed Mass air flow (MAF) sensor/volume air flow (VAF) sensor - low input
P0011 Raw code: 0011ECU: 11Status: Confirmed Camshaft position (CMP), intake/left/front, bank 1 - timing over-advanced/system performance
P0300 Raw code: 0300ECU: 11Status: Confirmed Random/multiple cylinder(s) - misfire detected
P0304 Raw code: 0304ECU: 11Status: Confirmed Cylinder 4 - misfire detected
P0303 Raw code: 0303ECU: 11Status: Confirmed Cylinder 3 - misfire detected
P0302 Raw code: 0302ECU: 11Status: Confirmed Cylinder 2 - misfire detected
P0301 Raw code: 0301ECU: 11Status: Confirmed Cylinder 1 - misfire detected
So kind of worried now, talked to the previous owner and he said he replaced the IAC, which seems to be true since the IAC looks pretty shiny. I’ll probably still have a look on the weekend. I had a look at the RPM and timing advance, attached to this message. Also, decided to record another audio clip from the exhaust this time, hopefully will help.
drive.google.com/file/d/1rTbdDqKWiMdjSV6...iJ/view?usp=drivesdk
I’ll have a look at the IAC this weekend, if there’s anything else worth having a look at before I check out the VVT, please let me know.
Thanks!
Here they are:
Thanks!
Last edit: 16 Feb 2024 14:12 by KimiKeemstar. Reason: Forgot to add photo
- Thank you received: 667
16 Feb 2024 14:07 #254376
Replied by DrRobin on topic ‘08 Jimny Rough Idle
That is a lot of error codes to be suddenly getting. Either something is going wrong big time or there is an issue with the elctrical system.
How good is your battery? Is it well charged or is it failing? When the battery is weak you can get some strange codes pop out.
Usually fuel trims within 10% are ok, within 5% is probably normal. My 2011 fuel trims will vary as much as yours at different throttle positions (I have them on screen all of the time as I use Torque Pro).
Robin
Robin
- KimiKeemstar
16 Feb 2024 14:19 #254378
by KimiKeemstar
I'll have a look at the battery tommorow. The thing is, the previous owner tried to wire up a dual battery setup but couldn't get an isolator set up. So i believe he ended up just wiring both up in parallel so it's not really a dual battery setup. There's no accesories connected to the car so there shouldn't be any drain on it. I'm confused as to which code to focus on now, but if there's any suggestions I'd be happy to accept.
Thanks
Thanks
- KimiKeemstar
17 Feb 2024 08:03 #254392
by KimiKeemstar
Hey guys,
Just had a look at the batteries, since they’re in parallel, both are at 12.44v. While I was under there, I also tried to test the MAF/IAT for any issues, by I only managed to get to step 7 of the attached flow chart since I don’t have multimeter leads long enough to complete step 8. But it seemed to be pretty good up to that point.
Another thing I was looking at was the timing advance in relation to the RPM at idle when up to temp. I’ve attached the figures below, but the timing advance does seem to fluctuate a bit at idle, is that normal?
I also looked at the MAF and MAP sensor readings at idle. The MAF seems to be within spec, but the MAP looks to be reading quite high. At the same time, the engine load was reading at 34.51%, at idle, which is weird because air con and accessories were off. Does having two batteries to charge put a higher load on the alternator?
I thought it was also worth having a look at the coil packs, the rubber ends seem to be wearing away as one of them was able to have the end removed completely. Reckon they’re worth replacing?
Anyways, gonna keep looking tomorrow, probably at the cam angle sensor and see if there’s anything up.
Thanks
Thanks
17 Feb 2024 08:52 #254393
Having two batteries does put increased load on the alternator if they are both flat. If they are in parallel you can get one battery discharging in to the other.
The reading of 12.44v I assume is without the engine running? If it without the engine on then that’s ok, perhaps a little low, but ok, it depends on the temperature.
Just out of interest what are you using to get the graphs? I use Torque Pro, but some of the values are derived rather than been measured, I think engine load is one of them.
I wasn’t sure that the Jimny has a MAP sensor, it has a MAF sensor, but I could be wrong.
Robin
Robin
Time to create page: 0.216 seconds
