Access to the steering box for adjustment (gen 3)
- GandHisJimny
Topic Author
- Premium Member
- Thank you received: 14
02 Feb 2024 16:05 #253966
by GandHisJimny
Jimmer II (2007 JLX+ auto in black & silver) : Android head unit, Black Raptor Steering Damper, Yokohama Geolandar G015s, rear cabin light, OEM wind deflectors
Access to the steering box for adjustment (gen 3) was created by GandHisJimny
Hi, I am trying to tweak some sloppiness out my steering wheel on my 70k mile 2007. I've inspected the usual suspects for wear (bushings, tie rod ends etc) and everything seems in reasonable enough shape so I'd like to give my steering box a little adjustment to see if it improves things.
Problem is, as a novice DIYer, it seems to be a bit of a pain to access because the fan cowling getting in the way. Am I missing something obvious here or do I need to remove or loosen bits to gain access? In the threads I've looked up nobody seems to mention this as a problem but perhaps they're just a bit more competent at jobs like this than I am!
Any pictures or guidance would be welcome.
- rogerzilla
02 Feb 2024 16:21 #253967
by rogerzilla
Replied by rogerzilla on topic Access to the steering box for adjustment (gen 3)
I need to do the same job. The cowl is attached by four bolts so you could take them out and see if there is some wiggle room? You can't actually remove the cowl while the radiator is in place, but it will move around a bit.
- GandHisJimny
Topic Author
- Premium Member
02 Feb 2024 16:56 #253970
by GandHisJimny
Replied by GandHisJimny on topic Access to the steering box for adjustment (gen 3)
Yeah, I'll maybe give it a closer look at the weekend. I was just surprised by how many posts and discussions didn't seem to acknowledge the difficulty of access so thought there might be some trick to it.
02 Feb 2024 17:25 #253971
by Busta
Replied by Busta on topic Access to the steering box for adjustment (gen 3)
I access it from the top with a couple of extensions on a ratchet. No need to remove anything.
The following user(s) said Thank You: GandHisJimny
- GandHisJimny
Topic Author
- Premium Member
03 Feb 2024 14:43 - 20 Feb 2024 08:54 #253994
by GandHisJimny
Ah, went out and can see the access isn't that bad from above. Looks like the LHD models are easier to access (per this video: ). The annoying thing with coming in from above with extensions is that you can't hold the screw in place as you tighten / loosen which isn't ideal.
Last edit: 20 Feb 2024 08:54 by GandHisJimny.
- rogerzilla
03 Feb 2024 16:06 #253997
by rogerzilla
Would a very long screwdriver reach? You can buy such things - I have a couple for obscure bicycle jobs.
Time to create page: 0.170 seconds
