Replacing brake slider pins on Aisin calipers
31 Jan 2024 20:19 #253927 by DrRobin
Cheers
I was hoping to be able to leave the brake lines attached, to save bleeding. I' guess I'll have to see how it goes.
I think the last time I did the job, I fully rebuilt the calipers with new pistons and seals, so had them on the bench
i didn’t disconnect the brake line, just swung them up and rested on the hub or calliper bracket.  Then holding the calliper and drift in one hand gently tapped the pins out with a small hammer.
Robin
The following user(s) said Thank You: robs5230
Time to create page: 0.142 seconds
