difference between wheel nuts / bolts for alloys and steels on the Jimny?
21 Jan 2024 16:49 #253639 by robs5230
Hi bit of a basic daft one but just wondering about what I have fitted
Just bought an 06 plate Jimny, with steels and off road tyres fitted and also supplied with the OE alloys and Duellers.
For now as I don't need anything other than mild off road ability, I'd like to refit the alloys and duellers (yeah I know).
But I'm not sure what studs, the steels are fitted with (the ones for the alloys or for steels)
Would anyone have a pic of what the bolts should look like for alloys and steels please?
Many thanks Rob
standard jimny - for now
21 Jan 2024 18:09 #253642 by DrRobin
Hi,
The studs are fitted to the hubs, so the wheel nuts are just that, nuts. The studs are the same length regardless of whether steel or alloys are fitted (someone jump in if that is wrong).
I am also fairly certain that the wheel nuts are the same for either steel or [standard Suzuki] alloys, someone will correct me if I am wrong.
I know the thread and nut depth are the same and the 'seat angle' also appears to be the same (60 degrees), so I can't spot any difference.
Robin
21 Jan 2024 18:48 #253644 by robs5230
Cheers for that
I think the steels are fitted on with the nuts that were fitted to the alloys, so hopefully all should be good to refit the alloys
Thanks
21 Jan 2024 19:25 #253645 by mlines
Yes they are both the same on the Gen3/Gen4 Jimny, so the nuts for Alloys and Steels can be interchanged.
However this is not necessarily true for aftermarket alloys or steels
21 Jan 2024 21:43 #253652 by fordem
The type of lug nut is determined by the particular wheel it's being used with - most steel wheels take a nut with a 60* tapered seat, most, but not all OEM alloys, including Suzuki's take the same tapered seat nut, but in general, if choosing an alloy rim, it should be visually inspected to determine the correct nut.
Look at the surface of the wheel where the lug nut will seat - if it has a tapered seat, then it needs a tapered nut, if it has a flat seat and an "oversized" hole for the stud, then it needs a shanked lug nut with a flat washer.
This is really about how the wheels are "centered" on the hub, wheels with tapered seats are located by the tapered nuts and are known as "lug centric", wheels with flat seats need a hub with a protruding spigot and a centering ring to locate them, and known as "hub centric".
The following user(s) said Thank You: robs5230
22 Jan 2024 08:30 #253657 by robs5230
I'll have a good look at some point. The Jimny was originally fitted with alloys, which I have, but the previous owner has recently fitted steels, with what I think are the original nuts from the alloys.
I'll whip one out and take a look.
The intention, is to refit the alloys anyway
Cheers
Time to create page: 0.359 seconds
