"Professional" mechanics
- Thank you received: 568
27 Jan 2024 17:25 #253825
Replied by DrRobin on topic "Professional" mechanics
According to the parts catalogue for my model it is 09401-30405
catalogs.ssg.asia/suzuki/?lang=en#bWFya2...Ymdyb3VwSWQ9PTU4MDYz
If yours is a different year/model the clip might be right.
The only thing to watch out for is excessive pressure in Jimnys often equals a blown head gasket.
Robin
Robin
The following user(s) said Thank You: rogerzilla
27 Jan 2024 17:36 #253826
Just looked up the two
09401-34503 is a 35mm clamp see
simssuzukiparts.co.uk/products/new-genui...amp-clip-09401-35403
Whereas 0940130504 is a 40mm clamp see
simssuzukiparts.co.uk/products/6x-new-ge...amp-clip-09401-30405
I think the pipe is 30mm so you would think your clip would be better.
- rogerzilla
27 Jan 2024 19:29 #253829
by rogerzilla
Replied by rogerzilla on topic "Professional" mechanics
No other symptoms of a blown gasket and it leaks worse on short trips where it doesn't get very hot. When it isn't leaking, the level in the expansion tank does exactly what it should - goes up about an inch when warmed up, and drops back to the line when completely cold again.
- rogerzilla
29 Jan 2024 10:12 - 29 Jan 2024 10:57 #253863
by rogerzilla
The dealer that sold the clips says I need the 40mm ones instead. This doesn't make much sense if the 35mm ones aren't holding. It's worth mentioning that jubilee clips weren't successful either at stopping drips, although the hoses didn't try to creep off. This does point to excess pressure.
Edit: turns out the 40mm ones were measured when open but the 35mm ones were measured when closed! So the 40mm ones are really 30mm and yes, the fitted clips are too big. So I'll be under the car again this weekend
Last edit: 29 Jan 2024 10:57 by rogerzilla.
29 Jan 2024 13:47 #253874
40mm is what the parts list diagrams says, so makes you wonder why they sold you 35mm?
The reason why Jubilee clips don't work is that everything expands when it gets hot, plus the pipe will soften slightly and the once tight Jubilee clip won't have enough pressure to hold the pipe in place.
At least with the correct clip, it maintains pressure even when expanded as it is applied by a spring force not a preset screw thread.
The only other thing that might have happened, a lot of pipes harden with age and it might be that the pipes are no longer soft enough to seal?
Robin
Robin
- rogerzilla
29 Jan 2024 17:02 #253879
by rogerzilla
The size is within the range for the hoses fitted and the website says "for all Suzukis". And I gave the reg number at the time. They have sent incorrect parts before; I should really use the local dealer!
The parts diagram I looked at had an obsolete part number for the clips, so that was no use.
Time to create page: 0.204 seconds
