Quick sanity check rear axle bearing grease
- Jimima
- Visitor
20 Jan 2024 10:54 #253598
by Jimima
Quick sanity check rear axle bearing grease was created by Jimima
Hi just done both rear axle/wheel bearings and seals on my abs gen3 jimny. Im Assuming the genuine suzuki/koyo bearings are filled with some kind of magic grease as the diff oil cant get past the axle seal and you dont fill the abs ring cavity with grease and the bearing doesn't really lend itself to having grease packed in it having a flat plate on one side and a rubber seal on the other.
Just wanting to check im not making a rookie mistake not greasing the bearing somehow.
cheers
cheers
20 Jan 2024 12:32 #253600
by facade
Replied by facade on topic Quick sanity check rear axle bearing grease
Yes they come pre-greased with magic grease that lasts the life of the bearing. (mainly because when the grease comes out the bearing fails.....)
Check that the seal surface on the bearing retaining ring is polished and there is a radius on the leading edge to enter the seal, I fitted one that wasn't fully polished once and it leaked.
A smear of grease on the lip of the seal helps reduce any damage when fitting.
Time to create page: 0.127 seconds
