Negative switch problem, slightly different from normal.
17 Jan 2024 11:07 #253557 by yakuza
What Jimny ( model/ year) do you have?
I have to ask why the original one is not sufficient?
So What jimny and year model and market is this?
Doesn't all have the rear fog light?
does vary if it is down in the rear bumper lamps or up in the main rear lamp assembly between markets and year, but they all have them here in Norway.
17 Jan 2024 11:52 - 17 Jan 2024 11:58 #253558 by facade
I can't see your diagram, you can attach an image into a reply on here, but they come out small.
Anyway, if you have a 3 terminal switch with a telltale bulb, look at what I sketched, the tell tale bulb connects internally to one switch blade which goes to the load, and there is an odd terminal for the other end of the bulb (different colour or size) which either goes to earth (positive switching) or live (negative switching)
If the tell tale bulb is on all the time the circuit is "live"  it sounds like you have the switch blades wired backwards, swap the feed and load terminals over.
(normally the switch is put in the wiring to the relay coil like I did it, then you wire a fused live directly to the lamps through the relay contacts, but for a 21W bulb it makes no difference where the switch is)
Oh, and you are only allowed to use the rear fog in conditions of reduced visibility, when you are required to have either dipped headlights or front fogs on (or both if you really want...) so wiring it off a headlight or front fog feed is correct.
Last edit: 17 Jan 2024 11:58 by facade.
25 Mar 2025 00:22 #259896 by Alix786
Hey, I’m in the same situation as you,
Could you please give me a quick step by step guide as to how you wired the switch/rear foglight to the cars headlights.
I’m trying to get my car ready for a IVA test but struggling with the foglight to only work with headlights
Where did you get the live from the headlight to make it only work when the button is pressed!
Any help would be greatly appreciated
25 Mar 2025 00:37 - 25 Mar 2025 00:37 #259897 by fordem
Maybe stop focusing on the headlights and look at getting your rear fog to come on with the front fogs since that apparently is permitted???
Last edit: 25 Mar 2025 00:37 by fordem. Reason: reword for clarity
The following user(s) said Thank You: Alix786
25 Mar 2025 13:04 #259905 by Alix786
Yes I think moving forward that is what I will do, as I believe I won’t need any relays / diodes to be fitted also?
It seems to be the simplest way to make this work.
25 Mar 2025 13:49 #259906 by fordem
I would strongly suggest the use of a relay to switch the rear fog on/off, whether or not diode(s) are necessary will be determined based on the circuit used and how the front fog lights are wired.
