Oil (suspected) OSF hub
- Thank you received: 512
08 Jan 2024 18:27 #253366
Replied by DrRobin on topic Oil (suspected) OSF hub
If you have got a front drive shaft oil seal leak you almost certainly have a king bearing gone or going. As they need to come out you might as well change them.
The large knuckle seal only serves to keep the dust out, I changed mine when I did the king pin bearings but as Scimike says the waterproof grease does all of the work in keeping the water out.
Robin
Robin
- Thank you received: 667
08 Jan 2024 19:10 #253367
Replied by jackonlyjack on topic Oil (suspected) OSF hub
I always strip my hubs just so I can clean and visually check cv wheel bearing
When I change kingpin bearings just what I do
08 Jan 2024 20:37 #253370
by Busta
Replied by Busta on topic Oil (suspected) OSF hub
Surely you can check the wheel bearing without removing it?
When I do kingpins I don't even take the vacuum hub off. Just undo the brake carrier, steering arms, hub seal and kingpins then pull the shaft out with the hub assembly.
- Roger Fairclough
- Thank you received: 210
08 Jan 2024 20:50 #253373
by Roger Fairclough
Replied by Roger Fairclough on topic Oil (suspected) OSF hub
If the swivel has rusted then the swivel seal will rapidly deteriorate and water ingress will follow and that water will likely contain material that will destroy the integrity of the grease on the kingpin bearings and then the bearings themselves. On my LC the hub was fitted with a tapered plug on the op of the housing and I used that to put an amount of EP oil into the hub to lubricate the kingpin bearings. Yes, some would escape past the swivel seal, but this was easily wiped off. Overall the oil helped to prolong the life of the bearings.
As a matter of interest, when members replace the bearings, was it wear or corrosion that prompted the replacement?
Roger
Roger
09 Jan 2024 09:23 #253379
by Busta
Rusty swivel or not, the dust seal does not prevent the ingress of water. The bottom bearing fails due to corrosion, it's well documented.
Defenders also use an oil bath in the swivel but it's still not a perfect solution and makes any maintenance more awkward. I'd rather change 5 sets of Jimny kingpin bearings than disassemble a Landrover swivel once. It's a 45 minute job on a Jimny once you know what you're doing.
09 Jan 2024 13:36 - 09 Jan 2024 13:37 #253383
by facade
Replied by facade on topic Oil (suspected) OSF hub
I don't recall the LandRover being particularly difficult, it is just heavier!
As I recall, you just lose the brake, crack the steering joints and undo 6 bolts on the axle tube and the whole hub & swivel come off as one to do the housing seal. (Which means the swivel housings are replaceable when they rust unlike the Jimny- and they are hard chromed, not wafted with thin paint.)
The swivel bearings are virtually the same, there is a bit of faffing with shims and preload, but you don't get death wobble when you set them up properly, as there is a railko bush rather than a roller bearing at the top to act as a damper.
The trick is making sure that you are far enough from the wall that you can pull the halfshaft fully out (don't ask how I know.....)
Last edit: 09 Jan 2024 13:37 by facade.
Time to create page: 0.158 seconds
