Transfer lever jumping back into 4WD
01 Dec 2023 18:51 #252552
by moadi
Replied by moadi on topic Transfer lever jumping back into 4WD
I see, thanks.
Yes I already took out the prop shaft until I sort this out.
I doubt the old one was broken because of this as I never had issues with it for years and it always disengaged 4WD with no issues, never had to reverse.
02 Dec 2023 09:41 #252573
by Busta
Replied by Busta on topic Transfer lever jumping back into 4WD
Just to confuse matters slightly, if you are using 4wd as intended e.g. in situations where the tyres can easily slip, the difference in axle speed from having the wrong diffs actually makes very little difference and won't cause any harm. There is a far bigger discrepancy between axle speeds when you turn a corner, even if you have exactly the same diff ratios. The transmission is designed to be able to cope with this as long as you are driving in appropriate conditions.
The following user(s) said Thank You: moadi
03 Dec 2023 19:35 #252595
by moadi
I see, well right now it stays in 4WD even when I’m offroading (slippery surface) unless I reverse
Time to create page: 0.395 seconds
