Gen 4 springs on a Gen 3
23 Oct 2023 21:08 #251697
by Busta
Gen 4 springs on a Gen 3 was created by Busta
I'm interested to know how the Gen 4 suspension springs compare to those on a Gen 3. Can anyone shed some light? I'm sure they will physically fit but a side by side comparison, or information such as the number of coils, wire thickness and free lengths would be great. Does the Gen 4 still have handed springs on the back?
With everyone opting to immediately ditch the standard suspension on their new Jimny's I'm wondering how my older one would sit on some nearly new springs.
- Thank you received: 2001
24 Oct 2023 03:27 #251702
Replied by Lambert on topic Gen 4 springs on a Gen 3
They are not handed apparently and when I did the maths they worked out giving a standard jimny approximately 30mm extra height. What that will be in reality is probably less I would think.
31 Oct 2023 09:05 #251885
by Chops
Springs do fit in a gen3, they are a smidge higher spring rate front and rear but otherwise will fit.
Replied by Chops on topic Gen 4 springs on a Gen 3
Gen4 springs are definitely handed. There's 15mm more preload on the drivers side and two different part numbers for the rear. Fronts are not handed and same part number left and right.They are not handed apparently and when I did the maths they worked out giving a standard jimny approximately 30mm extra height. What that will be in reality is probably less I would think.
01 Nov 2023 18:07 #251904
by Busta
Replied by Busta on topic Gen 4 springs on a Gen 3
Sounds like a perfect cheap upgrade to my ageing gen 3 suspension. Thank you.
Time to create page: 0.436 seconds
