Jimny 3 - removal of end caps from factory longitudinal roof rails
21 Oct 2023 17:28 #251622
by Bosanek
I have heard (and experienced personally) that it is very difficult to remove the plastic end caps from factory longitudinal roof rails from a Jimny 3 without damaging (breaking) the internal plastic latches in the caps.
I am referring to the rails marked in red rectangles in the attached photograph.
Today I found this report in a South African forum:
www.4x4community.co.za/forum/showthread....ing-Jimny-Roof-Rails
The writer over there presents a method for which they claim that it works to remove the plastic end caps without damage.
I do not quite understand with certainty what did they use as the removal tools and how as English is not my primary language.
Could somebody elaborate a bit more clearly, or if you have performed a successful removal yourself, present your own method.
- rogerzilla
21 Oct 2023 17:32 #251624
by rogerzilla
Replied by rogerzilla on topic Jimny 3 - removal of end caps from factory longitudinal roof rails
Heatshrink is just a thin rubbery plastic used around electrical connections. Heat makes it shink around the wires. The size you would need to fit around a typical ruler would be unusually large.
- Roger Fairclough
- Thank you received: 225
21 Oct 2023 18:16 #251626
by Roger Fairclough
Replied by Roger Fairclough on topic Jimny 3 - removal of end caps from factory longitudinal roof rails
How about Duck Tape?
Roger
Roger
- Thank you received: 2001
21 Oct 2023 20:46 #251635
Replied by Lambert on topic Jimny 3 - removal of end caps from factory longitudinal roof rails
Basically you need a very thin tool that you can feed under the edge of the trim to apply upwards pressure. However the reactive force is applied to a painted surface which you will want to avoid scratching so you either need a set of bought plastic trim tools or you need something like the ruler in the link with something else to stop it doing damage. Of course the other option if you are strong enough is to grip the trim with your hand and squeeze the inboard edge slightly while simultaneously lifting the outside edge up and towards the centre of the car. The issue with this is you need to apply a fair amount of force quite gently, it requires technique as well as brute power.
21 Oct 2023 21:49 #251636
by gv42
Replied by gv42 on topic Jimny 3 - removal of end caps from factory longitudinal roof rails
I have done it on 5 jimnys and breaking or damaging it all the time
21 Oct 2023 21:51 #251637
by gv42
so I buy new ones from SUZUKI SIMS
Time to create page: 0.265 seconds
