How many cells are in a stock catalyst?
19 Sep 2023 17:13 #250897
by Vandoni
How many cells are in a stock catalyst? was created by Vandoni
I have a gen 3 Jimny with the 1.3 gasoline engine, how many cells is the stock cat?
I want to replace it with a sportier one because the stock one choked the engine too much.
- Thank you received: 537
19 Sep 2023 19:10 #250902
Replied by DrRobin on topic How many cells are in a stock catalyst?
The Jimny has two CATs one in the manifold pipe and one under the car. Most ‘sports exhausts’ decat the system but that may not be road legal where you are.
I am not sure how much you will gain by a decat, possibly not very much. The front cat is known to break up and block the main cat when it is old, so a new standard exhaust might be just as good as a sports exhaust.
19 Sep 2023 19:13 #250903
by Vandoni
Replied by Vandoni on topic How many cells are in a stock catalyst?
it has 2? mine is a 2000 model, in the manual it says it only has one, but anyway, i'm asking this because i already removed the middle cat and right now i want to get a sporty cat to be able to pass emissions and make the car a little less noisy, since i also threw away the muffler that was full of holes and put a sport bike muffler in place of it
20 Sep 2023 11:10 - 20 Sep 2023 11:20 #250910
Replied by yakuza on topic How many cells are in a stock catalyst?
it varies between markets and local emission regulations if it has the two cat setup with the heated two stage systems or a single one or even none.
I got just the one in line now and empty box at the manifold and still luckily passes emissions test, but sometimes give an engine fault code i delete ever so often. I bought an aftermarket generic cat of roughly the same size spec for 2l engines.
Edit: Mine probably being too big might make it run too cold and thus setting off the fault codes.
Last edit: 20 Sep 2023 11:20 by yakuza.
20 Sep 2023 14:30 #250917
by Scimike
Have you tried wrapping the exhaust up to the cat to keep the heat in?
Had need to do this on our MR2 to keep the emission tester happy, appears to have worked for me.
In the spirit of Vandoni's original post, just in case no one knows the cell count, what alternative "off the shelf" under floor CAT or exhaust pipes exist?
The market (UK) is full of the BM Exhaust offering which I have fitted on ours, buts its just started to blow, so anything else out there other than the stock Suzuki and BM?
Replied by Scimike on topic How many cells are in a stock catalyst?
21 Sep 2023 10:07 #250940
I think you found it, thanks!
haha well I actually did the opposite and replaced the original insulated pipe from the manifold and down for a wider non-insulated one.
Time to create page: 0.148 seconds
