Coolant system help
19 Oct 2023 13:39 #251577 by Bennyb7
Replied by Bennyb7 on topic Coolant system help
Update:
I had the shop machine the head and install a new headgasket. I ordered a new waterpump and hoses at the mechanics advise. I was overjoyed to have my working jimny back.....until today. It's been about 5 miles of driving since I got it back and the coolant overflow tank cap popped off while driving. I heard the pop and saw the temp gage climb so I immediately pulled over and shut off the engine. Waiting for the mechanic on the side of the road now and praying to any God that will listen that no damage was done this time.
my questions:
what could have caused this? There must have been too much pressure in the system. Im guessing the same thing caused the first rupture. Could the thermostat be the issue? Should i remove it? I live in a warm area where temps never get below 50f
19 Oct 2023 18:23 #251589 by Bennyb7
Also when the heat is on, it doesn't blow warm...
19 Oct 2023 19:52 - 19 Oct 2023 20:03 #251592 by Scimike
Replied by Scimike on topic Coolant system help
Sorry to start with bad news, but to me it still sounds like your head gasket or another route is pushing combustion gases into the cooling jacket. This sudden pressure can push the water out, causing the expansion bottle to fill and your heater run cold (no water in it). I am assuming this bad news as you heard the "pop" first, then the temperature went up, suggesting it was over pressure before temperature.
I would pull the plugs and look for coolant in the cylinders. Also drop the oil and see if it's making its way into the oil.
A stuck thermostat won't help, but more likely to just overheat initially rather than blow the coolant out. But if it overheats enough you get head problems.
Check the plugs / cylinders for coolant.
Check the oil for coolant
Check the thermostat.
Check the radiator flows - IE it's not blocked.
If you suspect thermostat change it and try again, nothing to loose, it will work or it won't at this stage. Hope it's just the thermostat or block radiator and I am completely wrong with my assumptions.
Mike
Last edit: 19 Oct 2023 20:03 by Scimike.
20 Oct 2023 07:10 #251595 by Busta
Replied by Busta on topic Coolant system help
Did they check the head for cracks?
Time to create page: 0.091 seconds
