Re:Pipe identification
- RogersJimmy
20 Aug 2023 13:39 #250398
by RogersJimmy
Pipe identification was created by RogersJimmy
Could someone please identify these 5 pipes, from top to bottom, on my 2000 model Jimny? Thank you.
20 Aug 2023 14:42 #250399
Replied by mlines on topic Re:Pipe identification
Brake pipes and fuel pipes
Sent from my ThinkPhone by motorola using Tapatalk
The following user(s) said Thank You: RogersJimmy
- RogersJimmy
20 Aug 2023 15:13 #250400
by RogersJimmy
Replied by RogersJimmy on topic Re:Pipe identification
Thanks Martin,
Also what are these pipes on the offside front suspension arm please?
20 Aug 2023 15:17 #250401
Vacuum pipes
- RogersJimmy
20 Aug 2023 15:22 #250402
by RogersJimmy
That's great, thank you. I don't have to worry about them as I have freewheel front hubs and the vacuum disabled.
21 Aug 2023 09:14 #250428
by facade
Replied by facade on topic Re:Pipe identification
The 2 very thin pipes are brake lines, the thickest pipe is fuel supply, and the two middle sized pipes are fuel return and tank vent.
Keep an eye on those fuel pipes, they rust badly especially at the bend under the driver's feet and spray a fine mist of fuel out when the engine is running, which causes a smell.
Changing all 5 pipes is an all day job but perfectly do-able even on the drive (you have access to a lift- luxury!) you need the 3 sizes of copper alloy pipe, a flaring tool for the brakes, 2 sizes of fuel hose and clips.
You have to cut the pipes into small pieces to get them out of the clips- new clips are £££ from Suzuki
Time to create page: 0.178 seconds
