Ignition barrel change
10 Aug 2023 19:35 #250205
by CB1289
Ignition barrel change was created by CB1289
Hi all,
I recently snapped my key in the ignition of my 2001 Jimny and so have replaced the barrel with a second hand one off eBay. It came with two keys and was fairly straightforward to fit.
Only problem is since I have fitted it the car is struggling to fire up - the engine starts to turn but won't kick on and start.
Is it possible that the ignition barrel change is to blame?!
Cheers
Cheers
- Thank you received: 537
10 Aug 2023 19:55 #250206
Replied by DrRobin on topic Ignition barrel change
I think the key fob has a tag in it to switch off the immobiliser, see the following link
www.bigjimny.com/mediawiki/index.php/Key...g_transmitter,_alarm
If your Jimny has this then you either need to swap the tag over or reprogram the immobiliser unit to accept the new key.
The following user(s) said Thank You: CB1289
10 Aug 2023 20:17 #250209
by CB1289
Replied by CB1289 on topic Ignition barrel change
Hi,
I could very well be wrong, but I thought by replacing the entire ignition barrel and using the new keys that arrived with the part it would also sort the immobilizer out?
To be honest, it could well be something else causing the problem as I notice the coolant level is a lot lower than I remember! It's basically on the minimum value so wondering if there are problems elsewhere?
10 Aug 2023 21:19 #250213
by LesNewell
Replied by LesNewell on topic Ignition barrel change
The immobiliser is independent of the barrel. If you have one there should be a coil that fits around the barrel. This is the antenna that picks up the signal from the key. The immobiliser unit then checks the key code and allows the engine to start.
One hack is to relocate the coil and tape the old key to it. This tricks the immobiliser into thinking you have a key with the correct code in the ignition. A better solution is to program the immobiliser to your new keys.
11 Aug 2023 00:09 #250214
by fordem
Replied by fordem on topic Ignition barrel change
You cannot just replace the immobilizer, or the ignition barrel & keys, they have to be programmed to work with the ECU - you either change all three as a matched set, or you reprogram.
If the ECU does not recognize the immobilizer or the keys, the ECU will disable spark & injection, and there should be dash warning lights to let you know that it is an immobilizer related issue.
11 Aug 2023 05:43 #250218
by CB1289
Ah ok that makes sense.
Apologies, I wasn't clear - I replaced the barrel and coil which detects the immobilizer signal - it all came as a single unit.
So it sounds like I need to get it to work with the ECU - any advice on this?! Is it a job for Suzuki garage or something I can do at home?
I don't remember seeing a warning light on the dash to be honest but I'll have a look next time.
Time to create page: 0.189 seconds
