Sound deadening of the engine bay only
- knownothoworwhy
06 Jul 2023 10:51 #249754
by knownothoworwhy
Sound deadening of the engine bay only was created by knownothoworwhy
Hi guys,
The problem:
I've a problem when offroading - the frequent onset of the engine cooling system.
Original cooling liquid is topped off,
Original air intake filter, changed out - just to be on the safe side.
Background:
I offroad, to photograph and film wildlife.
The frequent and prominent sound of the engine cooling system. I have a feeling it originates from two possible sources: (1) fan-blades cutting the air, (2) cooling pump action.
I'm pretty sure that the 1st source can be improved on (better efficiency - both in cutting the air and cooling the radiator pipes (i.e., cooling efficiency), by swapping the original fan with a 6 blade fan with a better profile.
I'm not sure if there is an after market cooling pump which is quieter than the original, while doing the same job, with the same or better efficiency.
-If anyone tackled this problem and tried some possible solutions, please share.
The problem:
Background:
06 Jul 2023 11:22 #249757
by Busta
Replied by Busta on topic Sound deadening of the engine bay only
The cooling pump runs all the time. Presuming you have a gen 4 Jimny the sound will most likely be coming from the electric cooling fan, however it could also be the air conditioning fan. The simple solution there is to switch off the air conditioning.
The following user(s) said Thank You: Gadget, lookonimages
06 Jul 2023 11:56 #249759
by lightning
Replied by lightning on topic Sound deadening of the engine bay only
lt's true that the aircon fan is very loud on the Gen 4 Jimny, although you can't hear it much inside the vehicle it might scare off any wildlife you were hoping to track.
06 Jul 2023 12:17 #249761
by Gadget
Replied by Gadget on topic Sound deadening of the engine bay only
If it's an intermittent sound on the Gen4, it's probably the air-con. If you turn the air-con off it will stop.
Time to create page: 0.333 seconds
