4" lift - 33 tires questions
02 Jun 2023 01:58 #249383 by jcvs17cr
Im planning on using the Badak extreme 33" for off road. In terms of the offset I havent decided, but I wouldn't mind trimming a little. Ideally I would like to keep the original rims.
In terms of the HD shats, would you get only for the front? If so, why? And for the CV, any brand that you would recommend?
[img
I found this photo of a Jimny using the same tires that I want but in 35". It looks great, at least for what I like.
02 Jun 2023 17:49 #249397 by jackonlyjack
Longfield shafts and cv's
Go with 26 spline if you can.... But.... This means you have to change out the 22 spline side gears from front differential. With a set of 26 spline gears from a rear differential
With that tyre size and weight plus grip they will give the standard front shafts and cv's will break [often]
Rear shafts are a little stronger so change these if you want to
[when you take out rear shafts for whatever reason you may notice that the splines are starting to twist at diff end this means it's time to go HD version Longfield]
Or some friends of mine do a full floating rear axle conversion these use front wheel bearing hub...... So carrying a spare means that it fits every wheel
The following user(s) said Thank You: jcvs17cr
11 Jun 2023 13:17 #249500 by Rabid Rhino
Suspension kit, half shafts, transfer case, prop shafts.
All this sounds spendy. Sit down & do the maths.
See if Tibus are selling a set of portals for cheap. If you dont ask you wont know.
Time to create page: 0.173 seconds
