Best seatbelt design for slopes?
23 May 2023 19:55 #249251
by CFJimny
Best seatbelt design for slopes? was created by CFJimny
I use our Jimny as a workhorse on our farm. Everywhere is very steep and when I get out on the slopes, the seatbelt locks and when I get back in, I can't put the belt on. Then I have to drive down/across/up the slopes without a seatbelt. This gets a bit twitchy...
Is there a better design which will attach quickly but won't be affected by slopes? Sorry for the noob question!
23 May 2023 20:30 #249254
by Busta
Replied by Busta on topic Best seatbelt design for slopes?
How about a seatbelt clip? They are simple devices that loop onto the seatbelt to stop it retracting. Then all you have to worry about is trapping the loose seatbelt in the door.
The following user(s) said Thank You: CFJimny
24 May 2023 06:41 #249258
by RainerK
Replied by RainerK on topic Best seatbelt design for slopes?
You could also install Rallye-seats with a 5-point seat belt. To install this is much more effort but if you frequently drive in rough terrain the increased safety might be worth the effort.
24 May 2023 10:16 #249259
by facade
The requirement in MOT manual appendix C is for 3 point belts (B,G &O) which I think is a typo as inertia reel are covered seperately in E&H.
I always had "words" with the MOT tester when I had harnesses in the Series III, as although they were obviously better than the original early 1970s fixed seatbelts, they were the "wrong" type for MOT.
The easiest & lowest cost solution is as Busta says, a clip to stop it retracting (take it off for MOT)
Replied by facade on topic Best seatbelt design for slopes?
Will a 5 point belt pass MOT?You could also install Rallye-seats with a 5-point seat belt. To install this is much more effort but if you frequently drive in rough terrain the increased safety might be worth the effort.
24 May 2023 11:18 #249260
by Busta
There is no issue with multi-point harnesses in an MOT.
However, having daily driven a car with bucket seats and harness for several years, they are a terrible option for a vehicle in regular use. The simple act of getting in and out takes considerably more time, and normal movements while driving are severely restricted, e.g. looking over your shoulder when reversing. They are also very expensive.
24 May 2023 15:33 #249264
by facade
I was nearly 30 years younger then, thinking about it now, I remember having to squirm into the harness and it being rather awkward.
Actually, I have a hazy memory of refitting the three point belt as well for daily driving and sitting on the harness.
I had forgotten that!There is no issue with multi-point harnesses in an MOT.
Time to create page: 0.176 seconds
