A problem with the vvt model automatic transmission, the first gear is slipping
09 May 2023 20:57 - 15 May 2023 18:09 #249061 by Levi sh
Hello everyone, I wanted to consult with you experts,I have a Jimny model 2005 model vvt automatic, ever since the day I purchased it there have been a few problems with the gear such as the combination to the "D" entering with a delay with a small kick and occasionally shifting gears was done with a small kick,Later on, first gear started to slip and it barely drove, I did a complete gear overhaul with a replacement kit including a gear brain and the problem still remained, the electric gear computer was tested on another Jimny and it works properly, It is important to note that all other gears work perfectly Except for the reverse gear which gives a kick but drives great.does anyone have directions for testing?updating,
I replaced the chalk brain with the sonoloids and the problem remained the sameI'm looking for an electrical diagram of the gearbox, if anyone has one, it can help me a lot
Last edit: 15 May 2023 18:09 by Levi sh.
10 May 2023 04:43 #249063 by Lambert
Is it giving any fault codes when you plug it into a reader? Could be solenoid valve related? When you had it apart I assume you gave it a thorough cleaning in the oil passages?
10 May 2023 14:03 #249072 by Levi sh
There is no fault code, there is no fault lamp, the passages have been cleared
Time to create page: 0.149 seconds
