2 injectors not pulsing
- Robbo
04 May 2023 07:39 #248949
by Robbo
2 injectors not pulsing was created by Robbo
Ok so I don’t have a jimny but I’ve got a carry 1.3 with the same g13bb engine
i recently changed the head gasket, timing belt and water pump. After reassembling I had the timing 1 tooth out so wasn’t running properly so pulled the belt off and made it all correct and now it won’t start. I’ve got spark and fuel pressure. Injectors 2 and 4 are spraying fine but injectors 1 and 3 aren’t.
I checked the wiring quickly with a multi meter and the have continuity but no pulse when kicking over whereas the other 2 did
any ideas on what I should check?
04 May 2023 13:48 #248957
by fordem
Replied by fordem on topic 2 injectors not pulsing
I want to say go back to the timing - if you have fuel on two cylinders it should start & run, although very poorly, the fact that it is not starting suggests it's not a fuel issue.
Before you do that, try starting it whilst spraying starter fluid into the intake - if it's a fuel problem it should start & run for as long as you keep spraying the starting fluid, if it doesn't, then it's most likely a timing issue.
Be very careful doing continuity tests, and always ensure that you are not applying voltage (from your continuity tester) to the ECU, you can cause problems that way.
- Thank you received: 679
04 May 2023 16:13 #248958
Replied by DrRobin on topic 2 injectors not pulsing
When you checked for an injector pulse was that with the injector connected or disconnected?
If the injectors were connected perhaps 1 and 3 are pulling the signal down? If disconnected it sounds like there is a bad connection or no output from the ECU on 1 and 3.
You can check the resistance of an injector, it should be about 12 ohms.
You should always suspect something you have just changed, what got disconnected when you did the head gasket, timing belt and water pump?
Robin
Robin
- Robbo
08 May 2023 07:14 #249000
by Robbo
Replied by Robbo on topic 2 injectors not pulsing
I think you’re onto something there mate!
I unplugged one of the bad injectors and it almost started but when all 4 are plugged in it has no chance. I popped up the injectors to see them and unplugged a hood injector and 3 injectors were firing. Plugged them all back in and it’s back to 2. But now I can’t get more then 2 going again so I guess it was lucky I seen that. I’m guessing the injectors are screwed and when I unplug one it has enough power to sometimes fire the others or the ecu is doing some crazy shit. I’m not 100% sure I’ll do some more investigating when I get my multimeter back
08 May 2023 08:10 #249002
by facade
Replied by facade on topic 2 injectors not pulsing
I'd focus on checking the injector wiring, you will have disturbed it when you removed the head and each time you fiddle with an injector.
If it uses the same ecu as a jimny each injector has a single separate feed wire from the ecu and an earth connection.
Check for any pinching of the wires, trapped wires or evidence of breaks.
- Robbo
13 Jun 2023 07:15 #249512
by Robbo
I’ve tried tracing the wiring back but can’t find any breaks. Does anyone have an ecu pin diagram or know what makes the injectors pulse? Is it the cam trigger
