Automatic transmission failure
- Joas
28 Apr 2023 09:02 #248862
by Joas
Automatic transmission failure was created by Joas
I have a 3rd gen Jimny, year 2000, with an automatic transmission. The transmission makes a rattling noise when I give it some gas both in neutral and in gear, but it goes away at high speed. If I press the accelerator slowly it doesn't do it, only if I blip the throttle in neutral or press it to accelerate from a stop. Has anyone experienced a similar thing, and what was your solution?
- Thank you received: 2005
28 Apr 2023 12:25 #248865
Replied by Lambert on topic Automatic transmission failure
When you say rattling noise is it a heavy sort of noise or a more tingly lighter noise? Have you been under the car and checked the propshaft joints and exhaust for obvious looseness?
Time to create page: 0.153 seconds
