Early ABS pump issue
- Jambls
27 Apr 2023 23:28 #248858
by Jambls
Early ABS pump issue was created by Jambls
Hi folks, in a bit of a situation here. I've got an intermittent ABS light on, and after following the
instructions
to read the code, I'm presented with code 61: "ABS Pump motor circuit". I've had a look at the wiring, and it seems fine, I followed a
service manual
to trouble shoot it and checked it was getting the voltage it should be, and it was. A bit of googling lead me to
this
post on here, where the solution seemed to be to replace it. For the record, it's a Japanese built 04 hard top, with the non-vvt M13a and the abs pump is marked Denso 81A1.
Only problem is, I can't find one anywhere. Ebay has nothing and I got in touch with BB autos, who don't have anything. I've found a few places that claim to rebuild them, but they're expensive and I'd have to take the car off the road for a week or so while it's away.
It also occurred to me that I may be able to convert to the newer pump, while it's can of worms plumbing and wiring wise, the controller is on the pump so it's probably possible. I'd rather not though.
Any ideas on sourcing a replacement or fixing the one I've got? Also, why are they not available? Are they a common failure point? I'm sure ABS was mandatory by 2004, so there should be a few years of jimny that have them. Ah well, any help is much appreciated.
- Jambls
02 May 2023 17:17 #248929
by Jambls
Replied by Jambls on topic Early ABS pump issue
Anyone know where I can get one?
02 May 2023 20:28 - 02 May 2023 20:30 #248933
by Scimike
Replied by Scimike on topic Early ABS pump issue
No idea sorry.
I did have a Google and managed to find one or two overseas, but quite expensive.
Unless someone has a better idea I can only suggest you search "breaking Jimny" on eBay and ask each what they have. About 43 listings at the moment, it's possible someone has the item. Sorry if you've already done so, not much help at this point.
Cant understand why they are scarce, not aware they are an item that normally fails.
Last edit: 02 May 2023 20:30 by Scimike.
- Jambls
03 May 2023 11:10 - 03 May 2023 11:22 #248937
by Jambls
Cheers for the reply, I've been contacting breakers, but no luck yet. Most of the results are for different parts off the same car from the same breakers, there's only actually 5 cars being broken and none have abs.
Last edit: 03 May 2023 11:22 by Jambls.
- Thank you received: 706
06 May 2023 14:24 #248987
Replied by jackonlyjack on topic Early ABS pump issue
The denso 81A1 are very rare
Also no one wants to rebuild one either
Only fitted to small amount of 2003 models
And 2004 changed it to a different type in 2005
Been looking for over a year now and second hand units sell for £300 ish
A lot to say it maybe non working too
- AleksaManta
10 May 2026 13:14 #264394
by AleksaManta
Replied by AleksaManta on topic Early ABS pump issue
Do you have an update for this problem? Im having the same issue... currently looking into geting a different denso abs module (133000-7070) at first glance they look almost the same. Found some info that they could be plug and play but not sure i trust the source.
Time to create page: 0.106 seconds
