4WD Light Flashing - Safe to drive??
15 Apr 2023 19:46 #248603
by JimnyStu
4WD Light Flashing - Safe to drive?? was created by JimnyStu
Hi All,
I'm having some troubles with this JB13 Jimny of mine - it's currently up on the hoist while I get some work done but I have a couple of questions that I'm keen to get answers for.
They seem pretty fundamental to me and I can't seem to find a definitive answer for (or as definitive as possible).
I'm going to have the front hubs rebuilt with the kit from the BJ website (not sure what the difference between SKF / KOYO bearings are tbh?) after the 4WD light started flashing last weekend when I was trying to lock the hubs in, didn't hear the normal click sound.
The 4WD green flashing light just kept on flashing so I drove it home - is the thing safe to drive like this? Is it possible that it could attempt to lock in the hubs 'at speed' and cause damage?
If the above is the case and the system is trying to engage the hubs then it seems somewhat pointless having the mechanic do the hubs work until the system for locking in the hubs is sorted out or it could lead to (in my mind) some sort of coggy explosion?
The thing does wobble and I've noticed that there's some oil leaking out from the knackered hub setup (blocked one of the vac hoses and causing the flashing) on the nearside.
I've opted to do both sides while we're on with the rebuild kit.
Given the apparent flakiness of this button based system if I decide that ditching the vacuum setup for freewheeling hubs is best then can someone explain how the whole getting it in and out of 4wd / 4low will work? I'm thinking that:
2wd button = disengage hubs
4wd button = engage hubs / take it out of 4Low
4low button = works as I would normally expect when it's in 4wd mode?
Thanks for any pointers with this.
- Thank you received: 1998
15 Apr 2023 21:14 #248606
Replied by Lambert on topic 4WD Light Flashing - Safe to drive??
Flashing green means that the 4x4 has not properly engaged which is more than likely, but not exclusively, the vacuum pipes to the hubs are leaking. As you said manual hubs are one alternative and come with the advantage of being able to use low range on a high grip surface if you don't twist the hubs in which is useful if you have to manoeuvre a trailer in a yard for example. There is also a down side that you have to get out of the car the first and last time you need 4x4 though you can switch between 4x2 and 4x4 just using the buttons if you are doing a mixed day of back roads and loose green lanes or fields as an example. Some people do leave the hubs twisted in permanently but it does increase wear and fuel consumption marginally. The other option is to replace the vacuum pipes and save the cost of manual hubs and if you use silicone rubber lines you should be free from having to redo the same any time soon unlike the Suzuki steel pipe that seems to rust for fun.
16 Apr 2023 08:22 #248611
by Busta
Replied by Busta on topic 4WD Light Flashing - Safe to drive??
When you say you're having the front "hubs" rebuilt, which bit are you referring to? Where is the oil leaking from? If it's the large swivel seal this is completely separate to the operation of the vacuum hubs. If it's the wheel bearings then the seal behind the wheel bearing is critical to vacuum hub operation, and a failed wheel bearing is a likely cause of a flashing 4wd light.
Details of how and when to use the 4wd system are in your handbook and a brief summary is written on the sun visor. The hubs engaging at speed isn't a problem, but driving continuously with it in 4wd is. As you have buttons for 4wd I believe, after detecting a vacuum fault, the transfer case will revert to 2wd. To get 4wd 2 things need to happen- the hubs must be engaged and the transfer case must engage drive to front axle. So hubs alone can not put the car in 4wd.
16 Apr 2023 08:45 #248612
by JimnyStu
Replied by JimnyStu on topic 4WD Light Flashing - Safe to drive??
Thanks Lambert - I guess what I'm trying to understand is if you have freewheeling hubs then I can expect to use the 4wd / 4wd Low buttons 'as normal' once the hubs are locked in?
16 Apr 2023 08:49 #248613
by JimnyStu
Thanks Busta
I'm doing the lot since the kits are only about £100 I figure replace all the parts that they come with while all the hubs are stripped down and apart. The Oil seems to be coming from the swivel seal but I read online that oil can contaminate the vacuum pipes when the area around there starts to get on in life - considering I've got a leak (on the nearside) and failure to lock the hubs in I figured 'do the lot' as it were...
With regards to the hubs engaging at speed - I was always under the impression that you had to be stopped to lock the hubs in with the button and I was worried that they could somehow lock in while in motion and cause greater damage?
16 Apr 2023 19:02 #248628
by Busta
So you are replacing the wheel bearings as well as the kingpin bearings and swivel seals? There is no path by which oil from the swivels can find it's way into the vacuum system so that is very unlikely to be the source of your issue.
4wd can be engaged at up to 60mph as per the instructions on the sun visor and in the handbook.
Time to create page: 0.292 seconds
