Knocking/ ringing noise when going uphill or at load
- farshi
08 Apr 2023 18:13 #248443
by farshi
Knocking/ ringing noise when going uphill or at load was created by farshi
Hi everyone, I'm driving a 2009 1.3L vvt jimmy with manual gearbox, about 150k on the engine.
when I'm trying to accelerate on all gears (usually 2nd and above) I hear a metallic knocking/ ringing noise that looks like it's coming from the engine area.
The more I push the pedal the louder it gets even if the car doesn't seem to accelerate and they stop once I let go of the paddle and reduce the load on the engine.
AC on also makes it appear more often.
I tried to check exhaust heat shields and none seem to be loose. It used to happen only on very steep hills but now it happens on every load situations.
I do need to replace valve head rubber gasket, it's failing, if that can be the cause.
I have some videos capturing the noise but don't know how to upload them.
08 Apr 2023 18:55 #248444
by fordem
Replied by fordem on topic Knocking/ ringing noise when going uphill or at load
What grade of fuel are you running? Try a tankful of a higher octane fuel and see if that changes anything.
What you're describing sounds like pre-ignition, also known as pinking & pinging, Incorrect ignition timing is a common cause of pinking under load, so once you've established (by running the higher octane fuel) that it is pinking, you can check the timing to see if it's out.
- farshi
09 Apr 2023 04:23 #248450
by farshi
Replied by farshi on topic Knocking/ ringing noise when going uphill or at load
I'm running 95, not so common to find 98 here but I'll try.
Since this engine has a timing chain and not a belt, how can the timing be off?
- Thank you received: 2001
09 Apr 2023 05:33 #248455
Replied by Lambert on topic Knocking/ ringing noise when going uphill or at load
Do you have a tow bar fitted? Some after market exhaust systems are incompatible with a tow bar and as the rubber hangers age they can allow contact. Also check the engine and transmission mounts for play and the transfer box too.
- farshi
09 Apr 2023 06:17 #248458
by farshi
No tow bar, and all exhaust and rubber mounts are in good condition.
- Thank you received: 673
09 Apr 2023 08:35 - 09 Apr 2023 08:43 #248460
Replied by DrRobin on topic Knocking/ ringing noise when going uphill or at load
I think Fordem might be right, it sounds like pre-ignition, under load (acceleration or on a hill) is when you hear it.
Although the timing chain might ot have moved, you might have a faulty cam sensor or a lean mixture, perhaps an air leak.
if it is pre-ignition and you have got to the ‘knocking’ stage it needs sorting fast otherwise you run the risk of damage to the engine. One way to tell is to pull the spark plugs and look at the colour check them against a guide (search online) if it’s white or the insulation is marked/broken or there is wear to the plug ends it is likely to be over-heating due to a lean mixture or pre-ignition.
Robin
Robin
Last edit: 09 Apr 2023 08:43 by DrRobin.
Time to create page: 0.174 seconds
