Outlet Prop shaft Oil leek
06 Mar 2023 13:00 #247925
by arthursc
Outlet Prop shaft Oil leek was created by arthursc
Hello and thank you. I am new to the site but have been researching the dreaded prop shaft oil leek.
I’ve read the pinned post here www.bigjimny.com/index.php/forum/7-jimny...-leaking-again-grrrr
I am 100% confident that this is the exact issue I can see from the underside of the Jimny. It’s a 2008 1.3 manual with electronic 4 wheel drive.
I am looking for the part numbers for the propshaft and the oil seal please and also where I can buy them.
thanks in advance
colin.
thanks in advance
colin.
14 Mar 2023 11:28 #248049
Replied by yakuza on topic Outlet Prop shaft Oil leek
Hi.
I just cleaned my driveshaft properly and put sealant on the welds at the driveshaft. has been good for a few years now.
Also changed the oil seal, can be found here: www.bigjimny.com/store/gearbox-rear-oil-seal.html
Time to create page: 0.182 seconds
