Re:Clock spring, Airbag /Horn
- PBMatrix
20 Feb 2023 15:38 #247689
by PBMatrix
Clock spring, Airbag /Horn was created by PBMatrix
Hello, first post here. I did do a seach for using the key words Clock Spring, Clockspring, and looked for Horn not working. Did not find what I was looking for.
Anyway, I posted in the For Sale or Wanted section, but want to double tap by posting here too.
Need one of the Clockspring, Airbag for a 2001 Jimny, SN413. they seem to be unicorn like, as maybe they once exsisted, but no longer do...
Or if someone could tell me how to run the flat wire inside the bugger, so that is doesn't bind after two rotations, that would be awesome.
Also, doing all of the axel seals, front and rear brake rotors, drums, pads, and shocks just for fun.
Thanks,
Eric
Thanks,
Eric
20 Feb 2023 16:24 #247691
Replied by mlines on topic Clock spring, Airbag /Horn
There are different versions of the clock spring over the years, so you have to get the correct one (connections vary)
I have one version here
- PBMatrix
20 Feb 2023 16:56 #247692
by PBMatrix
Replied by PBMatrix on topic Clock spring, Airbag /Horn
Martin,
Can you post a picture?
Eric
Eric
21 Feb 2023 08:59 #247697
Replied by mlines on topic Re:Clock spring, Airbag /Horn
- PBMatrix
21 Feb 2023 11:06 #247698
by PBMatrix
Replied by PBMatrix on topic Re:Clock spring, Airbag /Horn
Martin,
It looks like it will work as long as there are three wires exiting the back. One wire is common (ground?) one to the Airbag, and the third one to the horn. Please private message me with part cost, Import fees, and shipping costs to Germany. Eric
- PBMatrix
08 Mar 2023 15:20 #247978
by PBMatrix
Martin,
Received the clockspring today!! Looks great and it should work. Thanks much!!
Eric
Eric
Time to create page: 0.499 seconds
