Jimny overheating
  • RMFord
04 Feb 2023 18:12 #247352 by RMFord
Jimny overheating was created by RMFord
I have recently bought a 2004 jimny but am having some overheating problems. We have replaced the water pump, thermostat and flushed the system. Also got a new rad cap on the way. Anyone have any ideas of what could cause this?
doesnt look like the head gasket as oil cap isn’t gummy but have but a steel seal in to stop any new breakages in it.
04 Feb 2023 18:31 #247353 by DrRobin
Replied by DrRobin on topic Jimny overheating
Is it loosing coolant or are the levels staying about the same?
What about the radiator, is that getting hot? What about air flow over the radiator, it it blocked or has the fan coupling failed?
Does the heater work?
All because you are not seeing water in the oil you might have a cylinder to water way gasket leak, the way to check is have a look at the plugs or is the water system getting pressurised?
Assuming you are in the UK it shouldn’t be over heating at this time of the year.
  • RMFord
04 Feb 2023 19:40 #247354 by RMFord
Replied by RMFord on topic Jimny overheating
Thank you for your reply.
Yes located in the uk south east.
Coolant levels are staying around the same with it. It gets hot and the expansion bottle starts to boil. Radiator is getting hot at the top but not really at the bottom( top very hot to touch bottom cold slightly warm).
Spark Plugs are new replaced them last week along with new oil, oil filter, air filter and fresh coolant.
Heater was working it did stop for a little then started again.
05 Feb 2023 09:33 #247358 by DrRobin
Hot water enters the radiator at the top and exits from the bottom, if the top is boiling and the bottom cold it sounds like you have poor or no circulation.
If you have replaced the pump, always assuming it is turning correctly on the drive belt, it points to a water blockage somewhere, perhaps the radiator, a pipe or a water channel is blocked?
The heater water is taken before the thermostat, interesting it wasn’t working at one stage, but now is.
I wonder if the previous owner had a leak and chucked a load of rad weld in that has blocked the system?
Robin
05 Feb 2023 09:38 #247359 by DrRobin
The reason for asking about the plugs, if you have a leak from water jacket to cylinder, one plug will be washed clean, whilst the others will have the normal levels of deposits on them.
If it was your rad cap, I would expect you would be loosing coolant and there would be condensation around the cap although if the water in the expansion tank is boiling you are probably seeing some condensation anyway.
Robin
05 Feb 2023 09:56 #247360 by monstarghs
Replied by monstarghs on topic Jimny overheating
100% sounds like a blocked radiator best bet is to remove and flush with water if you fill from top it should empty as fast as you fill, you might be able to get away with back flushing it from the bottom if thats the case
Time to create page: 0.192 seconds
