Troubleshooting non-starting 1998 Jr botheimny after 4 years
13 Jan 2023 17:10 - 13 Jan 2023 17:11 #246861 by Adr1an
 Hi guys,
 Won't bother you with the details but to cut a long story short, this 1998 1.3 Jimny was not started since 2018 and it appears as it is not firing.
 Borrowed a good battery which turns the engine strong and removed most of the old gas then added some 5L of new one. No joy.
 With the key turned in the position that lights up the dash I cannot hear fuel pump buzzing. Can you confirm that on this model the fuel pump should be running when turning the key on that position?  (if not, how should I test it without having to remove the return fuel line)
 Also how to check the presence of spark at the spark plugs without damaging the coils? Thanks a lot. Sorry for the weird title, keyboard went nuts and I didn't noticed :)
Last edit: 13 Jan 2023 17:11 by Adr1an.
13 Jan 2023 19:44 #246863 by Adr1an
As a side note, there were two jump start attempts before borrowing another Jimny battery. One involved getting current from another running car and the other one used a larger spare battery.
14 Jan 2023 14:59 #246889 by fordem
Assuming a G13bb engine, each coil pack fires two plugs, disconnect the lead from the second plug (#1 or #3), pull the plug, refit the lead to the plug, hold the plug against the cylinder head and crank the engine.
The fuel pump should run for three seconds when the key is first turned to on after which it should stop and not run until the key is turned to start. It should run for as long as the key is in the start position, but it will not stay running if the engine does not start.
Another approach to troubleshooting is to get a can of starter fluid and spray it into the intake whilst cranking the engine - if it fires you have a fuel delivery issue, if it doesn't you probably have an ignition issue.
14 Jan 2023 21:46 #246898 by Adr1an
Thanks for the suggestions, that is correct, the motor is a G13BB. You mean #1 or #3 counting from the radiator or from the flywheel?
This being said, the car has quite a few rust spots, one of them being the support of the relay box neat the battery plate. (said support is all flaky, I can tear it up by hand)  Is any obvious ground spot that I should check knowing that it could prevent the engine from starting?
15 Jan 2023 11:23 - 15 Jan 2023 11:29 #246907 by RainerK
Generally, I would not expect that 5 year old gasoline that sat in an fuel tank and fuel system to be sufficiently flammable to start the engine. And topping up the tank with new gasoline also does not really help because the old gasoline is also in the hoses etc.
Still, I would first check if there is a spark with a separate spark plug without removing any spark plug or I would exchange all 4. If there is a spark, then try starting with some starter spray (be careful with starter spray, it is highly flammable and only use it outside).
If then the engine starts or coughs, then I would flush the fuel system and use new petrol. Maybe even use 5l of alkylate gasoline because it ignites better and often dissolves residues.
Of course check oil and cooling water first.
Last edit: 15 Jan 2023 11:29 by RainerK.
15 Jan 2023 21:34 #246929 by Adr1an
Thanks for the suggestion.
I'll check for spark tomorrow morning and post here the result. In case there's no spark what would be the first obvious things to check? (fuse? ECU ground?)
