Heater Matrix Problem
13 Jan 2023 15:39 - 13 Jan 2023 15:40 #246856
by Too Deer
Heater Matrix Problem was created by Too Deer
Afternoon all,
I have been lurking for a few weeks, trying to work out what I needed to look out for when buying a Jimny.
A few days ago, I took the plunge and splurged on a 58 plate Jimny that appears to be rust-free (or as close to that as they come) and I got it for a steal.
It seems as though there is an issue with the coolant system resulting in the following symptoms:
Upon inspection this afternoon, I found a random pipe (looks distinctly like a coolant pipe) underneath the passenger seat and the passenger footwell is full of coolant.
Soooooo..... I fear it is the heater matrix. Based on the requirement to remove the entire dash, does anyone know roughly how much it is likely to cost me to have it sorted? ....... just trying to prep my bank account for the pain!
Thanks!
- The heater will not blow hot
- The engine temp suddenly went into the red as soon as I came off the motorway on the drive home.
- Top pipe was hot and rigid
Thanks!
Last edit: 13 Jan 2023 15:40 by Too Deer.
13 Jan 2023 15:58 #246857
Replied by mlines on topic Heater Matrix Problem
I sell the heater matrix for around £75 delivered (depending on where you are) but have never changed one. I would check around that nothing such as a pipe or actuating lever has been kicked off by the driver or passenger
The following user(s) said Thank You: Too Deer
13 Jan 2023 16:09 #246858
Replied by yakuza on topic Heater Matrix Problem
Never heard of anyone having heater problems like this. But however there is from time to time overheating problems with the m13 engines, either cracked cylinder head or head gasket.
Worst case it could be that something has cracked open from the overheating causing the coolant to leak.
sorry for the scare, hoping it is just a hose.
- Thank you received: 677
13 Jan 2023 16:38 #246859
Replied by DrRobin on topic Heater Matrix Problem
It sounds like the matrix itself is leaking. I expect your coolant level is down, which is why the car has over-heated.
The pipe under the passenger seat is a mystry, is it matrix pipe size or bigger?
The heater matrix has two pipes coming off it, both steel, a feed pipe (hot water) and a return pipe which go in to flexible pipe, but as far as I know the flexible pipes are inside the engine bay, not the passenger compartment, unless someone has bodged/modified it.
If the flexible pipe was leaking, it would leak in to the engine bay not the vehicle interior.
I guess as a quick test, you could bypass the heater matrix inside the engine bay to see if the engine still over-heats, that narrows it down to the matrix.
Good luck
Robin
Good luck
Robin
13 Jan 2023 21:44 #246872
by Chilton
Replied by Chilton on topic Heater Matrix Problem
I've recently paid £500 for a local garage to fit a matrix to a gen 3. That was labour only, I provided the matrix. They had to remove the dash. I don't think I was ripped off, I think it just takes a long time to do and beyond my skills. At least I hope I wasn't ripped off.....!!
- Roger Fairclough
- Thank you received: 225
13 Jan 2023 22:18 #246873
by Roger Fairclough
Replied by Roger Fairclough on topic Heater Matrix Problem
Is the water in the footwell the same colour as the rad. water or is it clear like rainwater?
Roger
Roger
Time to create page: 0.182 seconds
