Jimny front wheel leaning in
10 Jan 2023 19:37 #246807
by Tbott
Jimny front wheel leaning in was created by Tbott
Hi I’m hoping someone can help, I brought a Jimny as a project for me to fix up myself then become my daily, unfortunately I’ve noticed that the top of the front drivers wheel is leaning in heavily. Could anyone give me advice on what it could be as this is my first car and new to all this. TIA
- Thank you received: 1983
10 Jan 2023 20:16 #246809
Replied by Lambert on topic Jimny front wheel leaning in
Welcome to the forum. There's a few possible reasons none of which are particularly cheap, it could be a wheel bearing has collapsed or a king pin bearing collapsed but it's also possible that the axle is bent. If you lift the wheel off the floor and attempt to rock it up down front and back that will point you at one of the bearings depending on where you get movement. Finding a bent axle is somewhat more difficult as getting meaningful measurements is not easy for the home gamer. The thing is all these things are to varying degrees inevitable if using a Jimny hard off road.
Time to create page: 0.164 seconds
