saab 2.0t in a jimny
04 Dec 2022 11:52 #246215
by perrie
saab 2.0t in a jimny was created by perrie
Hi guys,
I have been looking in to buying a jimny, and there is one for sale near me, a 3rd gen, for about 4000 euros, by my research a 3rd gen jimny only makes about 80hp, this would not be enough for my use. so i was looking for an engine swap, and ofcource found the 1.6 swap, that is the easy way but only increases power by a measely 15hp, so i was looking around and i can pick up a cheap saab with the 2.0 turbo inline 4 in it, makes about 150hp, has anyone done this swap, and or does anyone know if it is possible for a relatively low budget?
looking forward to the replies!
04 Dec 2022 12:18 #246216
by fordem
Replied by fordem on topic saab 2.0t in a jimny
First - the fact that you're asking this question suggests that you have little experience with engine swaps - if I'm correct on that - read on, if I'm not, then feel free to ignore any or all that I'm saying.
The Saab 2.0 is most likely from a transverse engined front wheel drive vehicle, you're going to have to "adapt it" to mount it in a longitudinal mount, rear wheel drive Jimny - this is going to involve modifications to things like the oil pan, oil pump pickup, This is in addition to other modifications that would be required if you started with an engine from a vehicle that was longitudinally mounted, adapter plate to the transmission, engine mounts, intake & exhaust manifolds and the cooling system.
The real challenge however is going to be mating the electronics and getting those to work - since you're not likely to be doing the work yourself the question translates to how deep is your pocket - and no this is unlikely to be a low budget.
Depending on which engine the Jimny you're looking at has, there may be other options besides the 1.6 - if it's the M13a, the M18a is a possible candidate, and you have the benefit of it being a relatively easy and fairly well documented swap, which improves the chances of it being done without the cost going too high.
What I'm curious about is WHY you feel that 80hp won't be enough for your use. What are your plans for the Jimny?
04 Dec 2022 14:33 #246217
by perrie
Replied by perrie on topic saab 2.0t in a jimny
I'm looking to do a big trip from the top of Scandinavia to the bottom of south Africa, for which i would bring an offroad trailer so I can bring a motorcycle and a bike with me. And for offroading with a trailer I would need quite a bit more power than stock. Hence the engine swap
04 Dec 2022 14:54 - 04 Dec 2022 14:59 #246218
by Scimike
Replied by Scimike on topic saab 2.0t in a jimny
I think you may be surprised what 80bhp can do in standard trim.
The Jimny is a strange vehicle. It's not very fast and can loose momentum on steep hills, so it feels like it couldn't pull the skin off a rice pudding.
Then you put a 750kg caravan on the back and it's not very fast and can loose momentum on steep hills, it's strangely just the same !
Its down to it's gearing, it can pull almost anything in the correct gear.
Extra BHP is almost wasted unless you change the gearing in some way, larger tyres etc.
I can see no problem with a bike trailer on the back, I've moved the caravan over a rough field in 4WL and it was no problem. Traction is always going to be the first problem you find, rather than lack of BHP. I would spend my money on Diff lockers if I was to off road with a trailer.
Not saying you shouldn't go for extra power, but you could save yourself lot of trouble fixing a problem you may not have.
Last edit: 04 Dec 2022 14:59 by Scimike.
04 Dec 2022 15:01 #246219
by perrie
Okay if you say so, I'll try it without an engine swap first, thanks for the info!
04 Dec 2022 15:35 - 04 Dec 2022 15:37 #246220
by Scimike
Yep give it a go first, small steps. You can always fit bigger engine etc after the bits in contact with the gound. That's good tyres and improving ground clearance if needed. Just adjust your cruise speed expectations to 50-60 mph (with load) and enjoy.
But I do like the idea of 2ltr version
Last edit: 04 Dec 2022 15:37 by Scimike.
