Re:Higher RPM upgrades?
30 Nov 2022 23:10 #246179
by Old Neil
Replied by Old Neil on topic Re:Higher RPM upgrades?
Sorry I Don't know if you have done this already
Remove viscose fan and fit thermo fan, you could even use Davis Craig electric water pump they sell a controller for electric water pump and thermo fan
I found out too big an exhaust will reduce power
Sent from my SM-A336E using Tapatalk
- Thank you received: 1999
01 Dec 2022 05:26 #246180
Replied by Lambert on topic Re:Higher RPM upgrades?
For reference and to further make the point, Riccy of this parish has managed to get a 1.8 version of the engine and even with extensive work including throttle bodies and a stand alone ECU he is only making around 130 hrsprs. Ok he is looking for torque not power but still an extra 40 hp from an additional 500cc and significant modifications kinda suggests that these are already very efficient engines that don't really have much more to give.
01 Dec 2022 10:44 #246181
by Vandoni
Replied by Vandoni on topic Re:Higher RPM upgrades?
Ok I understand, so unless I use forced induction or put some extensive mods I won't be able to get that much more out of the engine, well it's ok.
as for the cat, I'll see what I can do about the second sensor, hoping it's as you guys say and it doesn't regulate the mixture
- Thank you received: 667
01 Dec 2022 11:59 #246182
Replied by DrRobin on topic Re:Higher RPM upgrades?
See this article about fitting a deCAT exhaust (and what to do with the second sensor).
caracaltech.com/articles/article/61483ca32325529176db54cc
Robin
Robin
01 Dec 2022 12:03 #246183
If your de-CAT pipe has a hole for the second O2 sensor, then use something like this to move the second O2 sensor away from the gases and keep the ECU happy.
mtcmotorsport.co.uk/products/mtc-motorsp...en-sensor-boss-m135i
Alternatively, I have seen some plugs that give a false sensor reading, or just disconnect it, it will throw up an error code and you might get a CEL on.
Robin
Robin
01 Dec 2022 16:37 - 01 Dec 2022 16:38 #246187
by Vandoni
So if I move the sensor from the original cat to the catless pipe it'll give me a CEL?
But would the CEL put the engine in some kind of safe mode or would it still run the same?
Last edit: 01 Dec 2022 16:38 by Vandoni.
Time to create page: 0.366 seconds
