Help needed to find part PLEASE. What is this piece called?
- Ilikeburgers
21 Sep 2022 17:19 #245030
by Ilikeburgers
Help needed to find part PLEASE. What is this piece called? was created by Ilikeburgers
Hello there,
Hope you're all well.
Someone reversed into my Jimny in June and it still hasn't been fixed. The insurers are useless at doing anything helpful and the garage who is going to do the work keeps lying but I have to use them. It's only superficial damage. The grill, headlight and this bit of metal which nobody seems to know what it is. The garage first said first they had ordered it from Germany way back in June. They lied about its arrival and wanted my car in August. It would still be sat there now. They said the part had come in later, then was the wrong part, then a month later said the wrong part came in again. Does anybody know what this part under the grill above the bumper is called, outlined in yellow? Or what it's part number, please?
I appreciate any help.
- Thank you received: 1999
21 Sep 2022 17:34 #245031
Replied by Lambert on topic Help needed to find part PLEASE. What is this piece called?
If you send Martin in the shop in the top banner your vin number he should be able to provide a part number and possibly a stock level.
- Ilikeburgers
21 Sep 2022 19:11 #245034
by Ilikeburgers
Replied by Ilikeburgers on topic Help needed to find part PLEASE. What is this piece called?
Thanks Lambert!
21 Sep 2022 19:34 #245035
Replied by mlines on topic Help needed to find part PLEASE. What is this piece called?
21 Sep 2022 23:04 - 21 Sep 2022 23:07 #245039
by lightning
Replied by lightning on topic Help needed to find part PLEASE. What is this piece called?
ls the part beyond repair? We had a hit and run on our 2020 Jimny which resulted in a dent on the rear corner.
lt's pretty amazing what the body shop can do.
l was concerned about the repair because it's a complex shape with a double angle which fades into a curve.
But it's come back absolutely perfect and completely impossible to tell it's been repaired.
The work took two days and cost £450. l removed the wheel arch trim and interior trim to make the job cheaper.
No idea why the picture is on its side. lt's not on its side in my photos.
Last edit: 21 Sep 2022 23:07 by lightning.
- Ilikeburgers
22 Sep 2022 10:45 - 22 Sep 2022 10:51 #245048
by Ilikeburgers
Last edit: 22 Sep 2022 10:51 by Ilikeburgers.
Time to create page: 0.577 seconds
