suzuki jimny partially engaging its 4wd on it own
- Kirk6866
15 Sep 2022 13:46 #244978
by Kirk6866
suzuki jimny partially engaging its 4wd on it own was created by Kirk6866
2007 Jimny
suzuki jimny partially engaging 4wd on its own - I can stop the Jimny push the 4wd button all works as should you can here the hubs working the turn back to 2wd and its fine for a couple of days then the same thing - you here the noice of the suzuki jimny partially engaging again any ideas what is making this happen
Tx
Tx
- Thank you received: 667
15 Sep 2022 15:57 #244979
Replied by DrRobin on topic suzuki jimny partially engaging its 4wd on it own
The 4WD and 4WD-L switches on my 2011 Jimny, started to go faulty and they kept making contact when they shouldn't.
I disconnected the switch box and the problem went away, so opened the switch box and found that 2 of the 3 switches were fault. I picked another up from a scrap yard.
I have heard of wiring problems causing the same thing, but the switch box is quick to disconnect.
Robin
Robin
Time to create page: 0.272 seconds
